Hey Seasoned Harley TwinCam Wrenches...... I need your help and your collective, Hard Won Wisdom.......
I just bought this 2004 Ultra Classic and I got a smokin' deal on her, she has 40,500+ miles and is my FIRST HARLEY!!
I came to the forum and began to devour anything and everything on my 88 and on the Electra Glide Ultra Classic (FLHTCU/I) in general.
I quickly read about the cam chain tensioners and felt that I needed to check them out. I was hearing some engine rattling from that side of the engine but as I said, my first Harley. I am not familiar with the natural noises of the TwinCam engine.
So..... I took it to a local indie shop who's owner/operator boasts of 44 years of wrenching on Harley's EXCLUSIVELY......
He said my Ultra....."perfect man, I wouldn't touch a thing. Believe me, if there was anything wrong with those tensioners I would be able to hear it immediately." I asked about just cracking the cover and looking at them anyways and he got a bit impatient and said he would be glad to take my money but it wasn't necessary because...."after 44 years brother, my ears are trained well and I could hear any tensioner problems..." BTW and FWIW.......this "Local" Indie is in MEMPHIS, Tennessee...NOT Horn Lake, Mississippi..... I wanted to clarify that in case anybody who is on this forum knows the indie guys in Horn Lake. I like the shop in Horn Lake, Gemini Cycle Supply...............Gary is the mechanic/owner and he is knowledgable and very generous with his time, which is his money and lifeline. He is a consumate professional and knows his SH%@&T to be CLEAR.......The first guy is how I came in contact with Gemini...........
I've been a cage wrench all my civilian AND Military life, I just never cracked a nut lose on a Harley...........I decided it was time to just buy a manual and learn..........
Here are the tensioners..............
Primary........(not terrible for the mileage really from what I've read)
NOW.......The Secondary.....(disaster at any moment...)
ANYWAY.........LOOKING FOR A NEW INDIE SHOP.......(found one....LOL, thanks Gary)
I am trying to decide what to do and I need some wisdom and some advice.....without taking any more of Gary's time...
I am considering gears so I don't EVER have to think about the tensioner blocks disintergrating and clogging up oil passages and blowing my engine up when I am 3 states from home....
I have read all the great reports on the Hydraulic Conversions and the new compound the rubbing blocks are now made of and I realize this is probably true. I do plan on going with some Andrews 26 grind cams as I am just a two-up touring rider. We love going on long road trips and I want the torque and power to pass the big rigs on the interstate without too much shifting and I like to be able to get out of "tight" situations....that usually requires torque at low to mid revs........
Anyway......here is my pinion runout............Am I too far gone for gears????
This is my base......as close to 0.000" as I could get it: fuzzy pic
NOW THE MOST REPEATABLE MEASUREMENT: 0.00320"-0.00335"??
NOW THE ODD MEASUREMENT THAT IS SCARING ME......NOT REPEATABLE BUT I DON'T HAVE THE BEST SETUP:
It looks like 0.00350" which is not what I wanted to see at all...
Here's another one I got, (unfortunately):
HERE IS WHAT I SET UP TO TRY TO GET RUNOUT MEASUREMENT:
I know that isn't the best setup but it seemed pretty stable....
It is a cheap a$$ Harbor Freight Machininst 1" Dial Indicator (no ball bearing in the tip.)
Well....... am I too far out for gears? I am a little nervous as the manual I have (downloaded from here) says the "Serviceable Limit" on the Pinion Shaft Runout is .003", which is Under what I am reading. But I don't have the budget to crack the cases and have the crank trued and welded so I've got to run it regardless.......
I think I am o.k. for sure on chains......
But I do want gears....I've read where folks have run gears for thousands of miles and they had .005" runout when they installed them........
Anyway, thanks for the patience required to read this LOOONG post! Am I A......
LOL!
I look forward to reading your opinions.....
Brian P. (JuiceMan)
