Where are the parts? : V-Twin Forum: Harley Davidson Forums
Old 12-03-2012, 11:56 PM   #1 (permalink)
JuiceMan is on a distinguished road
WELL, if I get flamed, I get flamed.....
I've searched and researched, read and re-read several of the threads over and over.
It seems I am getting conflicting info. I've read, "Go with the SE -11 Cam Plate (Hybrid.) And I've read, "No, the 2007 plate is the one because it has no outer bearings, but you cannot use anything but Andrews "N" Series cams.
I've written Andrews, asking for a Cam Plate Conversion Kit and they have responded that they no longer sell a "kit." I have to order the parts through a HD dealer and then order the cams from them.
I've read about John at Herko...........I've been to the website, and it looks like Herko has had enough..........
I've been to e-bay to look for parts..........not easy to find what you need, when your not sure what you need...
I want to go hydraulic. I have a 2004 Electra Glide Ultra Classic FLHTCU/I. It is a T/C88 F.I. and it has 40,536 miles it. I pulled the cam cover and the tensioners are ready to pop. The main is over half way through (can't remember what I measured, but I have it written down, they are toast.) I could go another 1000 miles MAYBE????
Not gonna roll the dice.
I need to know what part #'s I need. I want the new cam plate that does NOT utilize the outer bearings, I want to use Andrews 26 grind cams.
What is the parts list from HD? I don't want to press in my cams, I don't want to use the new chain out front and the old one inside the cam chest.
I want the '07+ system with Andrews 26 cams.
Can anybody help me with the parts list???
You guys seem to know your stuff, I just cannot seem to find all the info I need in one (semi-one) spot or thread or post.
I appreciate those with the part knowledge and the time you spend helping me figure this out.
Not to take advantage of anything, but I am a disabled military vet.
Now, if I am an asshole for bringing that up.............so be it!! I've got to get my Hog back together for a trip to Safford, AZ in June. I leave June 06 and want to see my fellow warriors for a reunion......
If anybody can give me a parts list,,,,,,,,,,,,Thank You Sir/Ma'am....
JuiceMan
JuiceMan is offline   Reply With Quote
Old 12-04-2012, 10:54 AM   #2 (permalink)
djl
djl's Avatar
djl is on a distinguished road
Electra Glide Ultra Classic FLHTCU/I. I need to know what part #'s I need. I want the new cam plate that does NOT utilize the outer bearings, I want to use Andrews 26 grind cams. What is the parts list from HD? I don't want to press in my cams, I don't want to use the new chain out front and the old one inside the cam chest.
There are three ways to skin the cat; two that use the SE billet plate and one that uses the OEM plate. The two billet plate options are shown below and you have elminated the 25284-11 option because you don't want outer bearings, don't want to press in cams and don't want new front chain and old inner chain.
You can go with 25282-11 if you want the billet plate; you would need to order the other parts to complete the conversion since this is an update to the OEM plate and if you were upgrading you would already have the tensioners, chains etc.
The third and cheaper option is to use the '07 and later OEM cam pate and pump. Andrews and Herko used to sell a kit but the MoCo stopped that. Below is the list of parts to make this conversion but you will need "conversion" cams; the TW26N. You can order the parts from an online discount dealer like Newcastle, Chicago H-D, Surdyke, etc. and save some $$$.
I would also suggest the service manual for your bike if you don't have one and that you upgrade the inner cam bearings as part of the conversion; Torrington B148s.
djl is offline   Reply With Quote
Old 12-04-2012, 05:49 PM   #3 (permalink)
Still in one piece
fresnohog is on a distinguished road
PM sent. Hope it comes thru.
fresnohog is offline   Reply With Quote
Old 12-04-2012, 08:00 PM   #4 (permalink)
Bulldogrider is on a distinguished road
CONVERSION KIT IS MADE UP FROM THE FOLLOWING COMPONENTS:
62400001 Oil pump assembly:
25355-06A**Cam support plate assembly
4741A Cam Support plate mounting screws; (15 pcs req'd.)
11461 Retaining ring (for front cam)
25683-06 Inner roller chain
39969-06 Inner chain tensioner
4740A Inner chain tensioner mounting screws; (12 pcs req'd.)
25675-06 Outer roller chain
39968-06 Outer chain tensioner
942 Outer chain tensioner mounting screws; (2 pcs req'd.)
25285-08 cam spacer kit 6 spacers
25673-06 Crankshaft pinion shaft sprocket (17 teeth)
25244-99A Outer cover gasket
11293 O-Ring
11301 x 2 O-Ring
25566-06 Retainer/Bolt
25728-06 Rear camshaft drive sprocket (34 teeth)
24017-10* KIT-CAM BEARING ASY timkin bearings
This is what I used in my 01 RK with Andrews 26 N cams.
Bulldogrider is offline   Reply With Quote
Old 12-26-2012, 12:29 PM   #5 (permalink)
Buck99 is on a distinguished road
Did you bother to email or call him? He does more than just put kits together.
Buck99 is offline   Reply With Quote
Old 12-26-2012, 01:36 PM   #6 (permalink)
Dont use billet plate. Do use -06 up pump.
