Weird problem : V-Twin Forum: Harley Davidson Forums
Old 12-03-2012, 01:24 PM   #1 (permalink)
MORRISV1 is on a distinguished road
Question Weird problem
Ok guys, i have a strange problem, see what you think. On a 2001 heritige, bored to 95, stock carb w/ new jet needle, andrews tg21 cam, vance - hines exhaust, about 40 k. Mi.
On the highway at any speed over 62 mph it will run for about 3 -5 minutes and act as if it was out of gas. Pull in the clutch, wait 20 seconds, and it will run normally as long as i don't go over 62. It will do this every time over 62 mph. I have a pingle fuel valve and no vacuum line. Have checked for water in the fuel, and drained and re filled with fresh gas. And have a new gas cap.
Any ideas would help
thanks,
MORRISV1 is offline   Reply With Quote
Old 12-03-2012, 02:17 PM   #2 (permalink)
nowafatty is on a distinguished road
Has the plug covering the air-fuel mixture screw been removed?
nowafatty is offline   Reply With Quote
Old 12-03-2012, 02:25 PM   #3 (permalink)
thefour's Avatar
thefour is on a distinguished road
I had a similar problem. Tech found a tank vent hose kinked. He put a new hose on and the problem was solved. Might help you, good luck.
Sent from my SCH-I535 using Motorcycle.com Free App
thefour is offline   Reply With Quote
Old 12-03-2012, 07:13 PM   #4 (permalink)
Sua Sponte
RANGER73's Avatar
RANGER73 is on a distinguished road
[QUOTE=thefour;2201903]I had a similar problem. Tech found a tank vent hose kinked. He put a new hose on and the problem was solved.
Or a clogged fuel filter or pingle screen
SUA SPONTE
RANGER73 is offline   Reply With Quote
Old 02-15-2013, 07:17 AM   #5 (permalink)
Found the problem
Thanks for the suggestions. As it turns out i pulled the fuel line off of the carb and had good stream. So no screen on the pingle problem. I found that harley uses a thin wall piece of hose where the vent tube goes under the tank console. This hose apparently got weak and collasped. I replaced this hose section and the problem went away. So the tank venting was the problem.
Old 02-15-2013, 07:25 AM   #6 (permalink)
thefour's Avatar
Re: Weird problem
Glad to hear its fixed. Keep the shiney side up.
