EFI to carb swap IGNITION help needed - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 11-10-2012, 12:17 PM   #16 (permalink)
sealdoggy's Avatar
sealdoggy is on a distinguished road
I did mine a couple of years ago, here's my list of parts for the entire job on A 2000 FLTR, I went with the Mikuni HSR42 amazing carb.
Engine mount (with slot for choke) ……. 16315-99
Choke cable ……. 29229-88B
Choke elbow ……. 27580-88
Choke boot ……. 27582-88
Intake manifold ……. 27613-99
Manifold seals ……. 26995-86B X 2
Seal ring (carb/manifold)…… 27002-89
Ignition Harness ……. 32435-00
Manifold sensor (MAP) ……. 32316-99
Manifold sensor seal ……. 11291
Retaining clip ……. 38723-99
Retaining clip screw ……. 68042-99
Stock Petcock- 61338-94D
Stock CV40 Carb- 27412-99D / Mikuni HSR42
MM EFI Tank Conversion from Pingel
Screaming Eagle Ignition 32721-01A
Main harness 70997-06,
ICM 32622-04B,
Coil 31655-99,
carb 27412-99D not sure if choke cable is included,
Manifold 27613-06,
Top motor mount 16315-99,
Tank adapter 62842-00,
O-ring 11323,
Petcock 61338-02,
Washer 62172-02,
Nut 62161-02,
Filter 62170-02,
Top plate 75040-06,
Gasket 61402-02,
10 screws 1311D,
Harness 70369-06,
sealdoggy is offline   Reply With Quote
