new screaming eagle oil pump part # : V-Twin Forum: Harley Davidson Forums
Old 11-22-2011, 10:32 AM   #1 (permalink)
PalmettoDeuce wants to know Dino or Syn?
Planing on doing the Andrews hybrid cam chain tensioner upgrade. I see that their kit includes oil pump #26037-06. This is the same one included in the HD kit#25284-08, I would like to know the pump part# used in the newer kit part#25284-11. This pump has much better #'s than the older one. anyone able to source the part# for the oil pump used in the newer "orange plate" kit??
PalmettoDeuce is offline   Reply With Quote Quick reply to this message
Old 11-22-2011, 10:49 AM   #2 (permalink)
larryb123's Avatar
larryb123 wants to know Dino or Syn?
The part # you are looking for is 62400001
larryb123 is offline   Reply With Quote Quick reply to this message
Old 11-23-2011, 10:17 AM   #3 (permalink)
can't get that # to work on any parts suppliers website. Does anyone know if this oil pump will work with the 2007 model cam support plate that Andrews uses in their conversion kit?
TIA
Michael
2002 FLHRI
Old 11-23-2011, 12:19 PM   #4 (permalink)
hoghawler's Avatar
hoghawler wants to know Dino or Syn?
The new screamin eagle pump in the -11 kit is of the same design as the 07 and newer pumps. It will mate to the new style cam plate with no problem, however I've not been able to order the pump separately. Tried two times for customers and Harley kicked the order back both times. Parts manager says only available in the kit. Hope you have better luck.
hoghawler is offline   Reply With Quote Quick reply to this message
Old 11-23-2011, 12:38 PM   #5 (permalink)
I thought that might be the situation.
Old 11-23-2011, 02:10 PM   #6 (permalink)
hoghawler's Avatar
This thread got me thinking about that oil pump again, so I called a friend that claims to have an inside source on HD suppliers. He thinks the pump is being sourced through Jims, but it doesn't show on their web site. May be worth a call or may be a wild goose chase, up to you. Good luck.
Old 11-23-2011, 03:22 PM   #7 (permalink)
Jim's ?????
I think google found it
http://www.jimsusa.com/
