Originally Posted by Mtclassic
The cranks 04 and earlier are forged the cranks 05 and later are cast. It is much more common for 05 and up cranks to be out of true. 07 and up even more so.
If your heart is set on a 96" you can call AMS and his big bore cylinders are 96" vs 95". I have an 04 95" mild head work etc. I would be more willing to go bigger if I had timkin bearings but do not want to split the cases at this time to do it. I ride with plenty of 96's and they do not get any better mpg than I do and some get worse. If you have boring equiment you can bore your stock cylinders to 96" with no problem. some go to 98"
Thanks for the information as I did not know this. Interesting that your 95 gets as good or better gas mileage then the long storke 96. Years ago I had a storked shovel head I built with stock bore. A few years later I put the 3 5/8 bore and gas mileage went way down. Matter of fact when it was just storked it go better mileage then a stock 74 even with the big S&S carb on it if I keep my wrist out of it.
You would think with a longer stroke you would go father on one revolution then with a shorter stroke If all the gearing and such was the same.
Thanks I new the 95 inch cylinders are nothing but bored out 88 cylinders. I have a couple spare sets of cylinders and might bore out a set. I would prefer to run the Harley pistons with the Teflon or what ever on them. Does the Harley 95 piston have the Teflon?
I talked to two different certified Harley mechanics today and they thought you could interchange flywheel assembles by taking the spacer off the the motor sprocket shaft.
Thanks for the information. I really need to up date my manuals as all I have now is 2005 and earlier.
