Pro PadMBO EnterprisesCycleGear.comDan Vance RacingDiamond Bar ChoppersMotorcycle-CommunicationFuel MotoLeslie Kay'sCustom Dynamics
Old 10-12-2009, 08:48 PM   #1 (permalink)
rlsidwell is on a distinguished road
Cam Run In and Lifters
I am in the process of replacing the tensioners, cams, and lifters in my TC 88. Do I need to pump up the lifters before I install them, or just put them in dry (after lubing the outside of course)?
Second, is there a run in procedure I should adhere to when I first start it back up, or just take it easy for a little while and let everything get seated?
Thanks!
Rick
rlsidwell is offline   Reply With Quote
Old 10-12-2009, 09:06 PM   #2 (permalink)
kemo is on a distinguished road
Are you using adj push rods or reusing the originals. When I did mine I just soaked them in a jar of clean oil and installed and adjusted the p/rs. As far as the run in the lifters are rollers so not like runing in the flat bottom lifters.
kemo is offline   Reply With Quote
Old 10-12-2009, 09:08 PM   #3 (permalink)
mooooving out!
route66paul's Avatar
soaking them and/or pumping them up helps to get it right. If they are dry, you tend to get the adjustables too tight and then the valves stay open
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
route66paul is online now   Reply With Quote
Old 10-12-2009, 09:17 PM   #4 (permalink)
Thanks guys. I'm sticking w/stock pushrods.
Rick
Old 10-12-2009, 09:22 PM   #5 (permalink)
here is what I do and it has always worked well. I put the bike in 5th gear with plugs out and I turn the motor over using the rear wheel. I do this for a couple of minutes and it pumps the lifters up and gets oil to the top. some people use the starter to spin the motor but I like using the rear tire.
Old 10-12-2009, 09:26 PM   #6 (permalink)
FEAR.the killer of dreams
DenverRK's Avatar
DenverRK is on a distinguished road
I agree with MT... That's what I did on my 88 - 95 build.
2009 SG
Wild Pigs
SE Breather
SEST
2008 Night Rod Special SOLD
03 Heritage SOLD
DenverRK is offline   Reply With Quote
Old 10-12-2009, 09:43 PM   #7 (permalink)
You will have to do as MT says to align the oil pump, also use aligning dowels if you have them. Very important to align the oil pump, do your home work
Old 10-13-2009, 02:10 AM   #8 (permalink)
heavyduty is on a distinguished road
I changed mine 30,000 miles ago. Put them in right out of the package, adjusted to spec never had a problem since. Heard that soaking in oil does absolutely no good, don't know just my opinion.
heavyduty is offline   Reply With Quote
Old 10-13-2009, 03:36 AM   #9 (permalink)
msocko3's Avatar
msocko3 is on a distinguished road
Don't know about not soaking them. I always toss them in a jar roller down and fill it to the top and leave them there a couple days. Before install I use a oil can that fits the small hole at the side to force oil in till it comes out the top. I've never had a single tick at startup yet.
Blue and Silver Triglide Powered By The Underpowered Hot Running Bike Builders Of Harley Davidson.
msocko3 is offline   Reply With Quote
Old 10-13-2009, 12:01 PM   #10 (permalink)
BigMo
Mohead1's Avatar
What msocko3 said. before putting them in, take a hand pump oiler, and place nozzle in the top hole, carefully pump into the lifter, oil will come out the side port, do this watching for any air entrainment to be purged, then put them in place. No break in, they are roller cams. I do put assembly lube on the cams and the lifter rollers.
BigMo
