JardineProducts.comPro PadRRcycles.comBub Enterprises
American Side Road CycleLeslie Kay'sFuel MotoMotorcycle-CommunicationMotorcycle.com
Custom Dynamics
Old 10-12-2009, 04:00 PM   #1 (permalink)
cmurtha is on a distinguished road
Cable Lube in my Transmission??
I lube my clutch cable by removing it from the hand lever and tying a plastic baggie around the cable and putting a couple of ounces of cable lube in the bag so it drains down my cable. Maybe I`m just being picky, but a couple of ounces of cable lube ends up in my transmission case when I lube the clutch cable in this manner. I use 20W50 synthetic in my transmission. Does any body know if this may be harmful to the transmission. I`m debating changing my transmission oil just to be safe...Thanks all...
cmurtha is offline   Reply With Quote
Old 10-12-2009, 04:52 PM   #2 (permalink)
no it won't hurt anything but next time use whatever you are using in your tranny to lube the cable. I use the baggy method and put an ounce so of gear lube. It does not take very much.
Old 10-12-2009, 05:16 PM   #3 (permalink)
Good idea...thanks!
Old 10-12-2009, 05:39 PM   #4 (permalink)
hbmc's Avatar
That lube won't hurt anything... also sounds like you may want to think of a heavier tranny fluid will quiet it down too. Unless you live in the snow.....I just squirt W-D40 in the lines. Stuff is so light and mixes well with anything
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
hbmc is online now   Reply With Quote
