Why not on an 88"?
When you look at the H-D catalogue, they indicate that the SE heads won't work on an 88" with flat tops, but will if you use the high compression pistons? Why is this? Is there an interference problem with the flat tops?
hibuckhobby
"He is no fool who gives away what he cannot keep to gain what he cannot lose"
