Bub EnterprisesPro PadProCharger.comJekillandHyde.euMotorcycle.comJardineProducts.comMotorcycle-CommunicationMBO Enterprises
Old 09-21-2009, 09:44 PM   #1 (permalink)
hodshire is on a distinguished road
Its ticking again
I just had my cam chain tensioners changed over to the new style with new pump and baisley spring. Quiet as could be in the top end for 800 miles then this weekend the old tick was back even louder. I wonder if the rockers moved off axis or need a shim. This bike is driving me nuts. My 09 does not sound like a pushrod is going to shoot out the rocker box why does this 06. I should have put in new lifters but with 8000 miles it should not need them. I thought the high pressure oil pump would take care of top end noise and it did for awhile. Any thoughts on this.
hodshire is offline   Reply With Quote
Old 09-24-2009, 05:40 PM   #2 (permalink)
kink04fxd's Avatar
kink04fxd is on a distinguished road
Sounds very familiar.
kink04fxd is offline   Reply With Quote
Old 10-24-2009, 08:31 AM   #3 (permalink)
thsorens's Avatar
thsorens is on a distinguished road
Join the club.
Black 04 Road King Classic. Andrews 26 cams, Arlan Ness Super Sucker, some SE offroad pipes and a PCIII.
thsorens is offline   Reply With Quote
Old 10-24-2009, 10:02 AM   #4 (permalink)
rob71458 is on a distinguished road
Been there, done that and a lot more than most. Gave up and dropped it off in upstate NY.
rob71458 is offline   Reply With Quote
Old 10-24-2009, 11:13 AM   #5 (permalink)
richeyo2 is on a distinguished road
i wish my 09 didn't tick, but it does and that sucks
richey -o
richeyo2 is offline   Reply With Quote
Old 11-02-2009, 09:02 PM   #6 (permalink)
njyamahauler is on a distinguished road
my 04 has been ticking since it was brand new. 35,000 now and no problems. I wouldn't worry about it until it breaks!
njyamahauler is offline   Reply With Quote
Old 11-02-2009, 09:29 PM   #7 (permalink)
shrinkman2 is on a distinguished road
Ya'll, why can't anyone find out what the problems is with this incessant ticking. I had same problem, rebuilt upper, now running 60 wt oil....when rebuilding engine put new set OEM lifters in...had a defect, went with hyperformance lifter and damn if I didn't have a defect in one of them. Much better now but still a little...but liveable now.....wasn't before. Is it just too much loose tolerance in some of the motors???? They don't all do it.
2005 Road King (Carb)
1550 SE 95" Flat Tops
R&R 525 Cams
Hyperformance Heads
Cometic .030 Head gasket
R&R Internal cam plate/oil pump
K&N Air Filter
Fullsac True Dual kit
Vance & Hines slip-ons
SE High Perf clutch spring
MRC Easy Clutch
shrinkman2 is offline   Reply With Quote
Old 11-03-2009, 12:07 AM   #8 (permalink)
Arrogant Bastard
jasilva's Avatar
jasilva is on a distinguished road
Check for exhaust leaks, take a bbq lighter and hold it up near the exhaust flanges while the engine is running and see if the flame flickers.
__________________________________________
If con is the opposite of pro does that make congress the opposite of progress?
Isaiah 6:1-9
jasilva is offline   Reply With Quote
Old 11-06-2009, 09:23 AM   #9 (permalink)
jammer45u is on a distinguished road
Turn up the volume on your radio, if it's anything serious it's bound to get worse.
jammer45u is offline   Reply With Quote
Old Yesterday, 04:05 PM   #10 (permalink)
46u
46u is on a distinguished road
My 02 Ultra has been noisy for just about 80,000 miles. When it was new it was really bad and the HD shop keep dicking me around so at 50,000 when I replace my cam chain adjusters I all so replace the lifters and it got much quieter but still not as quite as a EVO. I am getting ready to put the kit in that changes it to hydraulic tensiorner. The twin cam engines are noisy no matter what. I know many that have gone back to driving EVO because of it.
If you have adjustable push rods you can trying to readjust them.
46u is offline   Reply With Quote
Old Yesterday, 04:06 PM   #11 (permalink)
46u
If it where not for my radio I could not ride mine with the noise.
