HELP: 2005 Road King Engine Starting Problem
So, for about a week I needed to twist the throttle a quarter inch to get the engine started otherwise, I would just hear the starter going.
Now, I have to crank the throttle all the way full in order to get it going.
* I just changed the spark plugs a month ago.
* the battery voltage is okay (I checked it)
* once started, & if you get off the bike & stand 2 feet away from the back end of the bike, you can smell gas around the end of exhaust area
Any comments are appreciated.
Greg
