American Side Road CycleBikeBanditMotorcycle-Communication
AdvanstarMotorcycleShows
JardineProducts.com
Old 09-18-2009, 01:42 PM   #1 (permalink)
zoomie67 is on a distinguished road
Intermittent lifter ticking?
I've got a 2001 Fatboy with a GMR 98" kit, 615 cam running 10.8:1 compression. I've put a few thousand miles on it now and am getting some intermittent ticking in the front cylinder. It doesn't do it all the time. Every once in awhile it will randomly start ticking I park the bike for a bit restart it and it stops. I'm 90% sure it's a lifter. Should I replace the lifters?
zoomie67 is offline   Reply With Quote
Old 09-18-2009, 07:19 PM   #2 (permalink)
Armin's Avatar
Armin is on a distinguished road
I would say to change lifters, especially if you still have the original set in your motor. Use the HD 18538-99B lifters, the price is good, the quality is excellent, and if you have adjustable pushrods changing lifters is a piece of cake. You're done in one hour...
Armin.
Do it slowly, it's faster!
2001 FLSTCI
heads ported by BigBoyz
cylinders bored to 95 CI byBigBoyz
throttle body reworked by HorsePowerInc
SuperTrapp slip-on mufflers
K&N AC in stock housing
Andrews 37G cams with S&S gears
Feuling cam plate and oil pump.
CompuFire 3phase 40A charging system
ThunderMax Autotune ECM
PM Differential Bore calipers
the rest is stock and chrome cosmetics
Armin is offline   Reply With Quote
Old 10-16-2009, 06:32 PM   #3 (permalink)
TimberwolfZ28 is on a distinguished road
I was having a similar noise, but I'm not convinced it's a lifter (even though it's a similar sound). I have 10.75 CR and some choppy cams (37B) on my 95" motor.
With the compression being what it is, I'm leaning toward preignition/detonation with the heat it sees at idle. I pulled my plugs, and they did indicate a fairly lean condition, which would certainly contribute to the problem.
If we could get another warm day here in Michigan, I'd rejet the low speed circuit to fatten it up and see if it made a difference.
thoughts?
TimberwolfZ28 is offline   Reply With Quote
Old 10-17-2009, 03:24 PM   #4 (permalink)
DILLIGAF
berserker's Avatar
I got GMR lifters in my 98", for awhile I thought I had a lifter tick, when starting it in the morning, Around 10k. Did it for awhile. But I don't hear it anymore. Either it stopped, or its like the other Harley noises, you just get used to it.
From what I hear HD makes good lifters.
