Originally Posted by arthur6
Where should I start checking?
Is there a kickstand switch? Oil perssuer switch? Fuel pressuer switch??
Any ideas???
I would check your spark plugs first to make sure they both are producing spark while its turning over. If not, start working back from there (e.g. spark plugs -> spark plug wires -> coil etc).
The '03's don't have a kick stand switch. IMS, '07 was the first year to have a 'neutral' switch that would prevent the bike from starting when not in neutral.
There is a switch that will prevent the bike from starting if it has fallen over on its side (after a crash, for example). I don't know what its called, or where it is, or how to turn it off. Someone else on this forum should be able to help you out there, or you could check your owners manual.
Good luck...
