Originally Posted by ReformedHippy
I need a pic of the drain plugs on my 06 EG...any help is appreciated...
Do yourself a huge favor and pick up a service manual. FWIW, the engin oil drain plug is on the left side facing forward and the transmission is on the right side and faces down. There is a Hex plug in the middle which isn't used. The primary drain plug is on the bottom facing you just about dead center of the clutch cover, its quite small.
Blue and Silver Triglide Powered By The Underpowered Hot Running Bike Builders Of Harley Davidson.
