Originally Posted by 03GLIDE_
For the stalling problem try lubing the IAC pintle. It's inside the throat of the throttle body. You will see a little hole on the top of the throat looking into it. Spray some seafoam in it while working the throttle with bike running. Do a search on it. Many including myself have had this problem. Back firing out the exhaust is a lean condition or intake leak.
+1
although your not lubing it, your cleaning all the crap out of it. Your crankcase breathers feed oil mist into the intake and this little valve doesn't like it much. Make a habit of cleaning it out with some Seafoam or any decent EFI/Carb cleaner about every 5k miles, more often if you idle or drive around town a lot. The hole that 03GLIDE is talking about is on the filter side of the throttle plate. Spray it out with the bike running and be prepared to nurse the throttle to keep it running when you do this, engines don't run real well on carb cleaner and oil gunk.
__________________________________________
If con is the opposite of pro does that make congress the opposite of progress?
Isaiah 6:1-9
