RRcycles.comMotorcycle-CommunicationBub EnterprisesDan Vance RacingMotorcycle.comJardineProducts.comBikeBanditMBO Enterprises
Old 09-04-2009, 01:10 PM   #1 (permalink)
Spanner Head is on a distinguished road
Torrington INA cam bearings
Hi, when fitting these bearings do the letters and numbers on the bearing point to the crank or the cam. Thanks to anyone who knows the answer.
Spanner Head is offline   Reply With Quote
Old 09-04-2009, 01:12 PM   #2 (permalink)
I like children - fried.
plongson's Avatar
plongson is on a distinguished road
Towards the cam. When pressed in the case you can read the numbers. Some argue it doesn't matter, other are adamant they are directional. I installed them numbers out and have 10k miles on them.
2005 Road King Classic FLHRCI 88"
HQ-34's
HQ Pro-Tune
S&S Geardrive
Baisley LMR-2 15% pressure spring
Arlen Ness Big Sucker
Python pipes
And YES, I have the SERVICE & PARTS MANUAL
plongson is offline   Reply With Quote
Old 09-04-2009, 01:14 PM   #3 (permalink)
Doof Toll Pimp
ktwillys's Avatar
ktwillys is on a distinguished road
It really doesnt matter you can install them either way it will not affect the performance of the bearing..
That said I almost always (if I am paying attention) will install the bearing so that I can read the numbers without having to take the bearing out. if possible..
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DC.....
04 FLTRI
SE Welded/Balanced Flywheel
103 Cubes
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
Thunder Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is offline   Reply With Quote
Old 09-04-2009, 01:17 PM   #4 (permalink)
Thanks for the super quick replies, cheers.
