American Side Road CycleMotorcycle-CommunicationDiamond Bar ChoppersDan Vance RacingCycleGear.comBub EnterprisesBikeBanditMotorcycle.comMBO Enterprises
Old 09-03-2009, 06:22 PM   #1 (permalink)
jim-d is on a distinguished road
Angry compensator nut?
i have a 2002 roadking that has a knocking noise only when it is cold or after a long hard run and it sits for a hour or so, the noise only lasts for less then a minute and goes away, thought it was a lifter bleeding down but after two sets of new lifters the noise is still there, but it does not seem to do it every time, can a loose comp nut do this? or has anybody had this problem,? the bike has new cam bearings,cam plate,tentioners,oil pump,chains and new stock cams and lifters, all this was done 3000 miles ago, and just put another set of lifters in thinking that's what it was, the bike has 41000 miles on it, i run amsoil syn 20/50 every 4000 miles
jim-d
jim-d is offline   Reply With Quote
Old 09-04-2009, 11:24 AM   #2 (permalink)
prophet's Avatar
prophet is on a distinguished road
what side is the noise coming from? A loose compensator can make a knocking sound on the left side.
2006 FLHTCUI, 103", Wiseco's .010 over, SE Perf. Heads modified to 86cc's by Jay Riddle Racing, SE Pushrods, Andrews 55N with roller chain mod., S&S Lifters w/HTL, 3.37:1, D&D FatCat 2-1, Kuryakyn Hi-Five Breather, PC 3USB, 25 deg. injectors, Baisley Spring, 114 TQ/110 HP
prophet is offline   Reply With Quote
Old 09-04-2009, 01:59 PM   #3 (permalink)
bjornsson is on a distinguished road
I have not experienced it, but was told about that very scenario this week at a dealer. I pulled my primary apart for a compensator swap and discovered the nut was finger tight. The service manager at the local dealer said this happens more often than you'd think. I don't understand why, because this nut has lock tite on the threads and is torqued to 150 foot pounds. But the tech stated that it will sound similar to a rod knock when loose. I had no noise, so I guess it was not loose enough.
bjornsson is offline   Reply With Quote
