American Side Road CycleLeslie Kay'sPro PadJekillandHyde.euBub EnterprisesMBO EnterprisesMotorcycle-CommunicationCycleGear.comDiamond Bar Choppers
Fuel Moto
Old 08-27-2009, 05:35 PM   #1 (permalink)
CSM-H is on a distinguished road
SE 203 vs. SE 204???
Hey to all, looking for opinions on this comparrison for these two cams only. I have an 06 FLHT with a 95" BB kit, SE flat top pistons (.030 comtetic) and 203 cams,K&N airfilter (w/modified airbox) 103 mufflers and a FuelMoto PCIII.
So it's a basic question is the SE204 a better cam for this bike with this set up? I ride most of the time single, two up probably less than 10% of the time, looking for good low end, but better mid range and maybe a little on the top as I have the 6200rpm limiter.
I do intend to send the heads BigBoyz or ?, so the compression will be corrected at 9,2-9.5 all else will be the same......opinions please, thanks, CSM-H
CSM-H is offline   Reply With Quote
Old 08-27-2009, 05:54 PM   #2 (permalink)
Moneygreen
arealinvestor is on a distinguished road
JMHOP, with what you stated, i would run the SE 203 with the 36 degree intake close.Especially if you going to get head work & be at 9.5 corrected.Any reason why your not considering any other cams??? Because there are better cams on the market!!!
Craig G.
Old 08-27-2009, 08:09 PM   #3 (permalink)
strokerjlk's Avatar
call and talk to bean at big boyz.
He will explain the diff in the two cams.
A lot more going on between these two cams than intake close.
look at the lobe separation and lobe centers.
the 204's will give you a broader power band and build more Cly pressure......in a nut shell.
Call Bean he is very knowledgable and will steer ya right!
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 08-27-2009, 09:02 PM   #4 (permalink)
Old Fart
OldMsocko's Avatar
OldMsocko is an unknown quantity at this point
I had the SE 204 cams in my BB build on my 06 Ultra and loved them. Had Hillside do my heads and was running a Headquarters Pro Tuner. There is considerable difference between the 203 and 204 cams.
OldMsocko is offline   Reply With Quote
Old 08-27-2009, 11:28 PM   #5 (permalink)
aka_matt is on a distinguished road
the 203 is a good cam, its more choppy than the 204, (has more overlap and narrower LSA)
with beans heads and 9.6 comp, a friend made 95/95 on his dyna with the same basic setup u have...
Matt
FOR SALE
aka_matt is offline   Reply With Quote
Old 08-28-2009, 05:36 AM   #6 (permalink)
msocko3's Avatar
msocko3 is on a distinguished road
Never noticed much chop in the idle on the 05 FLHTCI that I had a 95" with 203 cams, it had some but not as much as the 204 cams in my dads 06 FLHTCUI.
Blue and Silver Triglide Powered By The Underpowered Hot Running Bike Builders Of Harley Davidson.
msocko3 is offline   Reply With Quote
Old 08-28-2009, 07:17 PM   #7 (permalink)
SE203 vs 204
strkerjlk, hey thanks to you and all else that answered. I believe you have answered it for me...204's it is.....again, thanks
Old 08-28-2009, 07:37 PM   #8 (permalink)
Bagger
95FLHR's Avatar
95FLHR is on a distinguished road
I have 204's in my Ultra. It is still an 88. Good low end torque and gets real happy at 2500 rpm and above.
95FLHR is offline   Reply With Quote
Old 08-28-2009, 09:18 PM   #9 (permalink)
strokerjlk's Avatar
No problem
ya gonna get bean to do those heads?
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 08-29-2009, 07:46 AM   #10 (permalink)
SE203 vs 204
strokerjlk, now we're into another subject.....I have been led to believe from reading here and other places that '06 heads flow pretty good and that although getting the heads done, it may not add much (2-3 hp/5tq) are numbers that I have read thrown around.
Comments are apprecited. CSM-H
No problem
Old 08-29-2009, 09:40 AM   #11 (permalink)
strokerjlk's Avatar
yes the 06 up flow very well.
as for porting heads...the numbers will vary with the other mods to the motor.
everything works togather.
using your number for reference only.
if the gains were 3 hp and 5 tq. while that dosent seem like a lot .
what if it carried that gain from off idle to 5500 rpm. you would feel a diff throughout your whole power band. throttle response would be much crisper also. The efficiency of the motor is going to go up so your will be making the same power at a lower throttle %. in a nutshell the porting will allow more air and fuel delivery through out a broader rpm range (velocity) vs the stock ports. while this may not be a huge number on paper it will feel and react on the street as huge!
As you go up in compression and cam lift, and timing this will increase also. so the numbers on paper will increase also. There is a point that it will run out based on efficiency.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 08-29-2009, 01:18 PM   #12 (permalink)
Doing heads for build...
strokerjlk, that fact I understood everything you said is scarey....Will be looking for heads now too. CSM-H
Old 08-29-2009, 09:50 PM   #13 (permalink)
Liker of Mid 60's FLH's
ChromeWelder's Avatar
ChromeWelder is on a distinguished road
It sounds like the decison has been made...but the 204's ROCK.
Near Ouray Colorado...June 2009
ChromeWelder is offline   Reply With Quote
Old 08-30-2009, 09:01 PM   #14 (permalink)
strokerjlk's Avatar
Give bean a call at Big boyz.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 08-30-2009, 10:32 PM   #15 (permalink)
Train
machinist is on a distinguished road
I am running a similar build to Strokers with Bean's heads, an LSR, and a mastertune TTS. What he says about the numbers and where you have them is on the money. I cant speak to a 203 since I never ran one. I went from stock to 204's. I wasnt looking for drag bike just a stronger cruiser and its a real blast having more torque at 2000 rpm then I had at 5000 rpm when it was stock.
you may be right
I may be crazy
but it just might be a lunatic you're looking for...
machinist is offline   Reply With Quote
