I went through this whole thing several months ago. There are a lot of posts on the subject. Some are on track and others may lead you astray. There are many factors involved as to if you should be worried about this or not. The nut is inside the outer primary cover just to the right of your left foot. You have to take the outer primary off but not the inner. There is a new service bulletin on how to torque it (don't use an impact wrench). You have to have something to keep everyting from turning (a special HD tool or an alternate from aftermarket). From memory, you take it down to about 70ft-lbs and then go another 1/4 turn but first you have to take it off, clean out all of the locktite out and put on new.
Now the rest of the story. You'll find a lot of information about "fixes" to prevent it from coming loose again. Some suggest drilling it out and putting in some shear pins while others say you should either shorten (grind down) the length of the nut (it's about 3 inches long) or put a washer between the face of the nut and the compensator. These latter suggestions are based upon the idea that the nut is bottoming out on the stator cover before it is tightening on the compensator. HD does sell a spacer washer but I learned after the fact (after using it) that the spacer is for bikes with the large stator (versus a smaller one). It is not to be used in all cases. I added the spacer and haven't had any problems but do have visions of the stator cover being a bit loose in there as the end of the nut is pulled away from the face of the stator cover.....but my compensator is for sure tight.
To the best of my knowledge, HD has NO service bulletins addressing the loose nut other than the revised torquing procedure; i.e. no mention of the washer.
So, if I had to do it over, I'd pass on the washer, put an extra drop of locktite (the instructions call for two drops of red (a special red that has a number I could only find at HD).
There's lots of details I could round up for you (the servce bulletin number, where you can get the special tool - it's maybe $20-$30, the locktite number, the width of the spacer washer and part number,....) but will only do that if you are serious about tearing into it. Let me know what you decide.
My suggestion is that if you don't hear a strange noise from this area of the bike, ride on and don't worry about it.
Brad
