Intermittent cut-out/miss on '02 FLSTCI
Ok, my first post here, been registered for a while, always found good info, thanks to all. Here's the deal. Wife has an '02 FLSTCI with about 24K on the clock, bone stock, the scoot has an intermittent miss/cut-out, buck, jerk problem. Had the fuel line in the tank replaced about 2K ago, fixed the problem for about 700 miles. Now it's back! She says it's the worst at 45-55 mph. Took it in to the local dealer, they checked battery connections and frame ground, No codes found, Installed latest ECM calibrations, checked main circuit breader connections, charging sys. output, fuel press. cyl. leak down, plugs and wires. The only thing they found was a dirty speedo sensor, cleaned that, everything else, so they say checked out OK. Service Tech said a new ECM may or may not fix it. Anyone else has a similar problem? Any suggestions? To me it acts like bad gas but she's run several tanks through it from different stations in different states even but the problem comes and goes. Again, any input is greatly appreciated. Wife ain't happy and you all know what that means!
