American Side Road CycleMotorcycle-CommunicationDiamond Bar ChoppersDan Vance RacingCycleGear.comBub EnterprisesBikeBanditMotorcycle.comMBO Enterprises
Old 07-04-2009, 08:44 PM   #1 (permalink)
Phil Grant is on a distinguished road
leak between trans and motor....
I have an 03 super glide with about 38000 miles on it. It seems to have developed a seep between motor and transmission, has anyone else experienced this before?? I assume it will gradually get worse. What would possibly be involved in correcting this....motor and transmission pulled completely out??? One wrench told me the motor would have to be completely split apart. Any input would be appreciated.....
Phil Grant is offline   Reply With Quote
Old 07-04-2009, 09:34 PM   #2 (permalink)
Pebble Cruncher
Rockbiter's Avatar
Rockbiter is on a distinguished road
There is nothing to fix, there are no fluids between those two components. There isn't even any sealant. What IS there is an open cavity, which allows road debri and other krap up inside between the engine and tranny.
Best option is to use a good cleaner and some elbow grease.
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote
Old 07-05-2009, 02:50 AM   #3 (permalink)
Infidel
Gulfstream's Avatar
The black residue you're seeing is fretting between the two surfaces. The MoCo should have installed a gasket or shim between them but didn't. Nothing you can do but clean.
John Levanger
Old 07-05-2009, 10:20 PM   #4 (permalink)
shovelmike's Avatar
shovelmike is on a distinguished road
Ditto
Ditto on what Gulfstream said, just clean it off from time to time and enjoy your ride.
This is my Granddaughter, Sky age 7. She can't walk,talk, or feed herself due to brain injury but look at that smile. It makes most of our troubles seem quite insignificant.
shovelmike is offline   Reply With Quote
Old 07-06-2009, 03:13 AM   #5 (permalink)
Seasonably Uncool
Sponk's Avatar
Sponk is on a distinguished road
Hi!
I have "The WEEP" on my FXDBI. It hasnīt gotten any worse since I first noticed it 10k miles ago.
Hereīs a gazillion posts on the topic if you care to read it...
C Ya
Sponk
Love- the feeling you get when you like something as much as your motorcycle.
-Sonny Barger
crashing sucks
Sponk is offline   Reply With Quote
