American Side Road CycleCustom DynamicsSportbikeTrackGearDiamond Bar Choppers
RRcycles.comJardineProducts.comFuel Moto
Old 07-04-2009, 10:51 AM   #1 (permalink)
Tim007 is on a distinguished road
Is the ignition module bad?
I ride a '03 FLHTC carbureted. I have 130,000 miles on it. I have always done the work on it until I needed a top end done (started using oil). I've always said if I couldn't work on it, I couldn't afford to own it. Nothing radical. Punched to 95" heads ported and polished. I put S&S 570g cams and switched to gear drive 70,000 miles ago, after going thru second set of chain tensioners. I didn't do any head work when I installed the cams. I won't get into all the BS that has got me here to THE question. During the top end rebuild, the stock ignition module went bad. Harley no longer makes the part. I found a used (right part # wrong rev need B it's A) one that works all right, but everything is not just right. I pull a trailer behind my ride every day. I run my business out of my bike. I know when it is right. A local shop here in Denver had a "Dyna TC 88 - 2 2001 carbureted models only". This is what is printed on the box, ignition module. I plugged it in, ran great for about 2 miles, then engine started cutting out. No pinging, just cut out, never quit. Adjusted curve down one notch from 38A curve to 36A. Rev limit set at 6000. It didn't change things. Mechanic thinks the problem is in my bike. I think it is the module. Any thoughts? I do not have steel core spark plug wires. I do have a manifold intake leak(minor, plugs look fine)which I'll get to. Thanks
Tim007 is offline   Reply With Quote
Old 07-04-2009, 11:02 AM   #2 (permalink)
springer-'s Avatar
Very first thing would be to fix the intake leak or you could be chasing your tail. Nothing else matters until the known problems are fixed. JMHO.
207-621-8089
Old 07-04-2009, 11:25 AM   #3 (permalink)
I knew I was going to get this answer. Just didn't think it would be the first. I'm already working on it. I'll post back when done. Tim007
Old 07-04-2009, 11:43 AM   #4 (permalink)
Faast Ed is an unknown quantity at this point
'03 FLHTC
No longer makes the part???
Faast Ed is offline   Reply With Quote
Old 07-04-2009, 08:47 PM   #5 (permalink)
The ignition module 32478-99b obsolete!! That's what the dealer says. Tim007
Old 07-04-2009, 09:04 PM   #6 (permalink)
springer-'s Avatar
I just went to Zanotti's website and put that number in and it shows it available still. $146.25
You can check here ... https://www.zanottimotor.com/shopping/pLookUp.php
207-621-8089
