CycleGear.comJekillandHyde.euCustom DynamicsMotorcycle.comMotorcycle-CommunicationSportbikeTrackGear
Bub Enterprises
Old 07-03-2009, 04:21 PM   #1 (permalink)
Hedghog is on a distinguished road
Need help on re-jetting a 40cv carb
I recently purchased a 2000 DWG with the twin cam 88 motor. The bike was totally stock. In the last couple of week I have installed V&H Big Shots and a AN Stage 1 Big Sucker air intake. Allthought the bike runs OK, it sounds like the carb needs to be re-set or re-adjusted. I was told it probably needs to be re-jetted. Does this sound right? If so, how do you know how big to go with new jets and is this real hard to do if I haven't done it before?
Thanks for your help,
Hedghog
Hedghog is offline   Reply With Quote
Old 07-03-2009, 09:14 PM   #2 (permalink)
The Dyno Man
Steve Handy is on a distinguished road
Woops
Hedghog
YOU CAN NOT CHANGE THE A/F and EXHAUST and not work the CARB........
.go to dealer and get a 46 pilot jet......
find the pilot jet in the carb.....it is not easy....
you will nead help.....
it is hidden in a hole in the bottom of the carb.....
the bowl must be removed first...
I get $75.00 to do this...
you got this info FREE
Good luck
Steve The Dyno Man
Steve Handy is offline   Reply With Quote
Old 07-03-2009, 09:43 PM   #3 (permalink)
blkfalc4 is on a distinguished road
Info here: Jetting
05' FXDWGI
Wearin' Down the Rubber
AMS 96.3 CI...KB cast flat tops @ 0 deck
Dewey 80cc heads, .030 HG
10.06:1 static...9.8 corrected CR
Andrews 54G cams
Supermeg 2-1
TTS...closed-loop
3.37:1
blkfalc4 is offline   Reply With Quote
Old 07-03-2009, 10:53 PM   #4 (permalink)
cantolina is on a distinguished road
Originally Posted by blkfalc4 View Post
Info here: Jetting
Good info, but you can find a lot of good info on jetting and tuning on your brother forum, XLFORUM...
Here's a good source of info for all things CV:
http://xlforum.net/vbportal/forums/s...d.php?t=491296
cantolina is offline   Reply With Quote
Old 07-04-2009, 08:02 AM   #5 (permalink)
Thank you for your help and suggestions.
Hedghog
