lifter blocks : V-Twin Forum: Harley Davidson Forums
Old 05-07-2009, 06:21 PM   #1 (permalink)
wanna ride's Avatar
wanna ride wants to know Dino or Syn?
lifter blocks
I decided to ordered some TWIN CAM EASY INSTALL HQ-4055 and BLACKOPS LIFTERS HQ-4225-04 , right now I have the HQ-4050 adjustable pushrods installed , with the stock HD lifters in my 02 TC 88. My question is if I loosen off the pushrods completly can I loosen the lifter blocks and with amount of available play from pushrods slide the lifter blocks and pushrods out at the same time so as to save me having to remove gas tank at rockers again? The lifter block in the manual appears to have a flat bottom allowing them to slide either way once loosened off.
Lynn
1999 Flht HeadQuarters 113 Build
2002 Dyna SuperGlide HeadQuarters 120 Build
1997 Dyna SuperGlide
wanna ride is offline   Reply With Quote Quick reply to this message
Old 05-07-2009, 06:45 PM   #2 (permalink)
rob71458's Avatar
rob71458 wants to know Dino or Syn?
Yes, I believe that will work, but it is easier to just cut the old push rods in half. Slide the push rod tube up so you can get at the push rod and then cut it in half with a bolt cutter.
rob71458 is offline   Reply With Quote Quick reply to this message
Old 05-07-2009, 06:53 PM   #3 (permalink)
wanna ride's Avatar
There brand new only been in the bike for a week and I will be replacing the lifters any way.
Lynn
Old 05-08-2009, 06:01 AM   #4 (permalink)
msocko3's Avatar
Sliding them out with the lifter block should work, thats how the S&S ones install.
2012 GL1800 Hannigan.
Old 05-08-2009, 06:57 AM   #5 (permalink)
rob71458's Avatar
Sorry, Forgot you already replaced them.
Old 05-08-2009, 09:44 PM   #6 (permalink)
Sturge's Avatar
Sturge wants to know Dino or Syn?
When you say lifter blocks I assume you're talking lifter covers?
I'm in the middle of reassy and I just installed mine yesterday. I believe the lifters will be in the way preventing you from sliding the cover out. You should be able to remove the top pushrod tube clip and slide the lower tube up allowing you to raise the lifter cover and clear the lifters. I've never done it but it seems like it would be doable.
02FXSTi...107" CI
S&S 4-3/8 stroker crank
Big Boyz Heads/CP Pistons - 10:1 CR
Andrews 37 cam
SE camplate/HO oil pump/tensioner upgrade
Dan Vance Ported TB (48mm)
SE II Slip-on's
Built by me with help from VTF
Sturge is offline   Reply With Quote Quick reply to this message
Old 05-08-2009, 09:52 PM   #7 (permalink)
wanna ride's Avatar
I believe your correct, when I first installed the HQ stock adjustable pushrods I found if I had another 3/16 clearance I could have pulled them out , so should be no problem.
Lynn
Old 05-08-2009, 10:07 PM   #8 (permalink)
route66paul's Avatar
This is the reason that most people go to adjustable push rods. standard length pushrods have .030 either way. If you mill .030 off the heads AND run a thinner gasket, it is then time to run adjustables or smaller push rods. adjustables are used most of the time so that a cam set change can be done without removing the valve covers and rocker arm assemblies.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
