Diamond Bar ChoppersLeslie Kay'sMotorcycle.comMotorcycle.com Classifieds!Stainless Ride Specialty AccessoriesPowerstar SparkplugsProCharger.comFuel Moto
Old 04-07-2009, 04:12 PM   #1 (permalink)
larose481 is on a distinguished road
Torque difference w/ baffles
I have an 06' Night Train with a set of the staggered bs without baffles and love the way it sounds. My question is, I was wondering if anyone has any real torque number differences between w/ or w/out the baffles. I am installing a set of Andrews 26's next week and will have to have it dyno tuned and was wondering if it is a huge difference with the baffles as I would prefer to leave them out and if I was to take them with me to the dyno and the map is way different between the two then I will get boned on the dyno price as they have a set price for a custom map and if I start changing things that will effect the map I am sure to pay for it. Other than the pipes, PCIII, and S/E air cleaner it is a stock 88". Thanks.
larose481 is offline   Reply With Quote
Old 04-07-2009, 04:37 PM   #2 (permalink)
dynarule's Avatar
dynarule is an unknown quantity at this point
Without the baff's you will loose on the low to mid but scream on the top, you need back pressure to gain torque. If you put them in (and i highly recomend you do) you will see an increase in your torque for sure,and it will still be plenty loud as i too have these same pipes.
dynarule is offline   Reply With Quote
Old 04-07-2009, 04:42 PM   #3 (permalink)
Dave63's Avatar
You need exhaust velocity for torque, which increases scavaging and improves performance.
Dave
Old 04-07-2009, 04:43 PM   #4 (permalink)
dynarule's Avatar
I think you may be wrong here!
Old 04-07-2009, 04:46 PM   #5 (permalink)
Dave63's Avatar
Please look it up so I can spare myself of explaining it again....
If engines needed backpressure to make torque, then dragsters wouldn't do 100 mph.
Or read:
http://www.thumpertalk.com/forum/sho...d.php?t=659727
http://my.prostreetonline.com/forums...php?t-1639.htm
Dave
Old 04-07-2009, 04:52 PM   #6 (permalink)
dynarule's Avatar
No Baffs = Top End!
Baffs = Low End!
Old 04-07-2009, 04:57 PM   #7 (permalink)
dynarule's Avatar
You might want to re read your own links. Why do you think they put those baffs in at the very end of the pipe? Speed up maybe? Put the restriction at the end and wa la.
Old 04-07-2009, 05:10 PM   #8 (permalink)
Dave63's Avatar
Yeah.... that's why torque cones are installed at the heads.
This is Engines-101...simple stuff. Same reason 2-1 pipes generally make more torque and HPs then 2-2 pipes. Exhaust veloicity.
Dave
Old 04-07-2009, 05:13 PM   #9 (permalink)
ULTRA LIMITED
laserp's Avatar
laserp is on a distinguished road
I'm no expert, but I believe the concept is to manage exhaust velocity. Without a baffle, it can be too high, torque dip. The baffle meters the exhaust velocity to where it needs to be, it,s not the back pressure that does it, it's tuning your exhaust pipe for your specific build. I've read opinions on this topic from the experts here and they all frown at the idea that it's back pressure your after.
02 FLSTCI, 117 in the works, Baisley Pro-Street Heads & corrected geo. roller rockers, Axtell kit 20 deg. reverse dome pistons 11:1, HPI 55/58mm MaxFlow throttle body, "Tman TR-662-1 cam", SERT, TSII+, RB C LSR 2-1 Pipe
laserp is offline   Reply With Quote
Old 04-07-2009, 05:14 PM   #10 (permalink)
dynarule's Avatar
Please go to tech school or something. This is Engines-101...simple stuff.
Trying to get the performance of baffs with the sound of drag pipes.
I think you may need to go to tech school. Engines 101. You may learn something today. LOL
Old 04-07-2009, 05:16 PM   #11 (permalink)
Dave63's Avatar
OK....I'll do that.
You can get the sound of drag pipes with no baffles by simply reducing pipe diameter, and increasing exhaust flow/velocity AND increasing torque at the same time.
No baffles.
Why do you think 1-3/4" pipe is best on HDs?
Using the term "Back pressure" for a system based on optimum exhaust flow, velocity and scavenging tells me volumes about your knowledge of how engines work.
Dave
Old 04-07-2009, 05:22 PM   #12 (permalink)
dynarule's Avatar
Too bad you live in PA, I would buy you a beer and have a good ol time. Speaking of beer!!!!!! its beer thirty.
Old 04-07-2009, 05:24 PM   #13 (permalink)
Dave63's Avatar
It's ALWAYS beer-thirty....
Back pressure is part of the equasion, but not the most important one.
Dave
Old 04-07-2009, 05:27 PM   #14 (permalink)
Faast Ed is an unknown quantity at this point
Pretty sure he was talkin' about low-end torque. If dragsters were cruising around the country, up and down mountains, I think they'd change thier exhaust profiles.
Faast Ed is offline   Reply With Quote
Old 04-07-2009, 06:57 PM   #15 (permalink)
Thanks for all the responses so far and how fast. What are we talking as far as a loss between the two? Is it minor but enough to feel the difference or is it a large amount? I put the baffles in it tonight and it is ok but I still like it better without. Just trying to see if it is a major killer and should run them. I am sure there is an improvement with the baffles as I have looked as much as I could find but wondering how bad it is without. Maybe the best thing for me to do before I tear it apart is reload a map w/ baffles and go try it and see what it rides like. I would still like to see if anyone has done any dynoing both ways or a little better idea. Thanks again for the responses as this is my first post and glad to see you respond.
