88 to 95 Big Bore Kits : V-Twin Forum: Harley Davidson Forums
Old 03-01-2009, 10:06 AM   #1 (permalink)
Bf109driver wants to know Dino or Syn?
Looking to up grade my 88 twin cam EFI 99 Ultra to a 95. Will pn# 29880-06 kit aside from the breather and pipes work with my bike? The reason I'm asking is found this kit kinda cheap.
Bf109driver is offline   Reply With Quote Quick reply to this message
Old 03-01-2009, 10:40 AM   #2 (permalink)
kinda cheap? pistons, bore your jugs, gaskets = $350 +/- , and your bore will be true, clearance will be correct.
Old 03-01-2009, 10:46 AM   #3 (permalink)
springer-'s Avatar
In the '99-'01 years the cam bearings were a problem. If it has not been addressed, you should consider that when doing the 95" build. Also replace your inner cam bearings with a full compliment bearing instead of the caged bearing that comes from Harley. Torrington makes a good full compliment bearing. How many miles on the bike? You should consider new lifters and probably chain tentioners as well.
Must agree that boring your cylinders is less costly and better results.
Check out Ride of the Month
207-621-8089
Old 03-01-2009, 10:52 AM   #4 (permalink)
Thx Clay, found this stage II big bore kit with the cams, jugs , pistons, rings and spacers for about $300. Comes with pipes and breather that I already have, (Stage II) on mine. Guy says its a new kit (29880-06) seald in the factory box.
Old 03-01-2009, 10:59 AM   #5 (permalink)
springer-'s Avatar
That's a good price. That kits is for a '06 FLHX. It includes (or should) replacement catalyst mufflers.
I would still consider boring your stock cyclinders for a better fit but you can use the cylinders in the kit. Keep in mind that you will have to add a fuel management device as well since your bike is EFI. A powercommander would be a good choice since is is an MM fuel injection.
207-621-8089
Old 03-01-2009, 11:59 AM   #6 (permalink)
george248 wants to know Dino or Syn?
Originally Posted by springer- View Post
I would still consider boring your stock cylinders for a better fit
I am with springer on this one... was going to buy new cylinders and pistons... decided to just send my pistons to a reputable builder and have him bore the cylinders. HD cast flat tops were mis-packaged... pistons were marked standard, but were .005 O/S... freakin rings were standard
Builder said this is the second set of HD pistons that he has seen like this.
george248 is offline   Reply With Quote Quick reply to this message
Old 03-01-2009, 02:16 PM   #7 (permalink)
bf109, that is cheap! hope all is as he stated. have fun adding power to your trusty steed. and remember what springer said-------those bearings can make a motor into a flower pot.
Old 03-06-2009, 12:27 PM   #8 (permalink)
Solamente inglÚs hablado
Evil MF's Avatar
Evil MF wants to know Dino or Syn?
I would also swap over to a Carb.
RIP
1999 FLHRPI
95" BB
GMR Welded & CNC heads w/ Vortex
CP Forged Pistons (14.1cc domes)
Delkron Billet Cam Support Plate
Fueling Super Oil Pump
Andrews 55G's
Andrews Gear drive
Ported Screamin Eagle Intake Manifold
44mm S/Eagle Carb (52 Slow,220 main, Bob Woods KT3 Needle)
Datyona Twin Tech ignition & Coil
Vance & Hines Pro Pipe HS
Screamin Eagle Race Clutch
Evil MF is offline   Reply With Quote Quick reply to this message
Old 03-07-2009, 07:02 AM   #9 (permalink)
Electra 1 wants to know Dino or Syn?
I have a 2001 FLHTCUI with the 1550 big bore installed. SE203 cams, SE air bracket and SuperTrapp slip ons. Stage 2 flash from dealer and the bike runs great. No fuel management installed. I did purchase a PCIII USB incase I needed too, but so far power and spark plugs show I don't really need it. If I were to go bigger in the cam department then for sure I would use a fuel management device. Just another opinion. If you are interested in a PCIII USB I might be interested in selling mine.
Electra 1
Electra 1 is offline   Reply With Quote Quick reply to this message
Old 03-07-2009, 07:59 AM   #10 (permalink)
springer-'s Avatar
Electra 1
Technically the Stage 2 flash is your fuel management device although not adjustable like a PCIII. A good tune with a more flexible fuel management device would be an improvement over what you already have. BUT if you are happy where you are just enjoy it.
207-621-8089
Old 03-07-2009, 08:51 PM   #11 (permalink)
Correct, but what I am saying is try it before you soak more into the build and see how it runs. Depending on the cam used will determine if you need a PCIII right from the get go. Sure if I wanted a few more horses the 260.00 PCIII and a 250.00 or more tune might be worth it, but for a SE203 cam not really is all I am saying.
Electra 1
Old 03-10-2009, 10:22 PM   #12 (permalink)
mark fisher wants to know Dino or Syn?
Cool idea! Then you could have fun with the choke, & tuning the carb, & altitude changes and...
Maybe get rid of that pesky electric starter & installa good ol' kicker too.
I did a 95" SE big bore kit on my '03 RK a few years ago. Haven't had any problems with it, and I'm happy w/ the (mild, by some's standards) power increase. It was easy to do. Whole new jugs. I think I still have the originals around here somewhere.
mark fisher is offline   Reply With Quote Quick reply to this message
Old 03-11-2009, 11:29 AM   #13 (permalink)
Evil MF's Avatar
Well With the 99 he has M&M injection... Very easy swap, do a searh on it. It's a night and day difference. You would be stupid to swap out on the 03 as you have the better injection system.
RIP
1999 FLHRPI
95" BB
Andrews 55G's
Andrews Gear drive
Old 03-30-2009, 09:51 PM   #14 (permalink)
Thx for all the info guys !
Old 03-31-2009, 08:39 AM   #15 (permalink)
well, how did it go?
