SportbikeTrackGearOriginal Bike SpiritsCustom DynamicsMotorcycle.com
BikeBandit
Bike Bandit
Old 11-01-2008, 08:43 PM   #1 (permalink)
FL_HIGHLANDER is on a distinguished road
Cam It Up
As an old hot rodder we used to put in a cam and pick up a bunch of hp.
With the economy the way it is I can't afford anything else, What cams would you put in for a little extra midrange power?
FL_HIGHLANDER is offline   Reply With Quote
Old 11-01-2008, 09:26 PM   #2 (permalink)
Moneygreen
arealinvestor is an unknown quantity at this point
Woods performance!!!!!!!!!!!
Craig G.
Old 11-02-2008, 06:56 AM   #3 (permalink)
skyhook is on a distinguished road
andrews 26
08 fxdse 110", r&r heads, 257 cam, hp inc 55mm, supermeg
skyhook is online now   Reply With Quote
Old 11-02-2008, 08:21 AM   #4 (permalink)
Axe Man
BVBOB's Avatar
Another vote for the Andrews 26, I also like the HQ 0034 for a bolt-in only cam but I feel the 26 has better manners at low speeds, the woods cams also work well but you did mention money being an issue and for cam only swap I could not justify the woods over the Andrews 26.
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
Old 11-02-2008, 10:32 AM   #5 (permalink)
mafosa's Avatar
mafosa is on a distinguished road
andrew 26.. just right for me.
andrew 26 chain cams, powercommander,samson pipes and arlene ness a/c
mafosa is offline   Reply With Quote
Old 11-02-2008, 11:43 AM   #6 (permalink)
mooooving out!
route66paul's Avatar
You really need intake and exhaust and then headwork as well as sizing. Have you head worked for the cams and you will have a good runner.
Depending which year you have. 07 and later really need a cam that has some overlap.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 11-02-2008, 04:56 PM   #7 (permalink)
Armin's Avatar
Armin is on a distinguished road
Andrews 26!
Do it slowly, it's faster!
2001 FLSTCI
heads ported by BigBoyz
cylinders bored to 95 CI byBigBoyz
throttle body reworked by HorsePowerInc
SuperTrapp slip-on mufflers
K&N AC in stock housing
Andrews 37G cams with S&S gears
Feuling cam plate and oil pump.
CompuFire 3phase 40A charging system
ThunderMax Autotune ECM
PM Differential Bore calipers
the rest is stock and chrome cosmetics
Armin is offline   Reply With Quote
Old 11-03-2008, 04:08 AM   #8 (permalink)
fatboydon24's Avatar
fatboydon24 is on a distinguished road
I probably asked this months ago,but how much we looking at for the andrews 26,s&s gears,everything to get the cam in and bike running.just cam,nothing else.
95"SE Build
SE HTCC Heads
SE HTCC Forged Pistons
SE 257 cams
SE Intake
SE Adjustable pushrods.
.040 headgasket(should Have gone to .030)
SE compression releases
V&H 2-1 pro pipe
HP=?;TQ=?
Jaw Hurting Grins!
fatboydon24 is offline   Reply With Quote
