Help Testing Crank Position Sensor : V-Twin Forum: Harley Davidson Forums
Old 08-25-2008, 07:58 PM   #1 (permalink)
SVD999's Avatar
SVD999 wants to know Dino or Syn?
Can Anyone Tell Me How To Test Crank Position Sensor On A 03 Twin Cam . I Have A Power Commander That When Hooked Up Only Runs On Front Cylinder, Runs Fine With Out It. Dynojet Seems To Think It Could Be Ckp Sensor. I Need The Service Limits And Proper Way To Check, Running ,or Just Cranking Or Any Other Specifics. I Believe It Is Checked In Ac Voltage
SVD999 is offline   Reply With Quote Quick reply to this message
Old 08-26-2008, 12:24 AM   #2 (permalink)
cts1950 wants to know Dino or Syn?
The crank position sensor is a magnet with a coil of wire wrapped around it. Your problem would not come and go with adding the power commander or not. I would guess it is the power commander and the wireing to it.
cts1950 is offline   Reply With Quote Quick reply to this message
Old 08-26-2008, 10:04 PM   #3 (permalink)
SVD999's Avatar
Dynojet Says Because It Runs Tru Stock Ecm First Then To Power Commander If Ckp Sensor Is On Low Side Of The Working Range It Can Cause Problems
Old 08-27-2008, 12:25 AM   #4 (permalink)
The output will be ac at varying frequencies too high for most voms to read I suppose a oscilloscope would read it correctly. The sensor is not that expensive. I keep a spare in the tour pak
Old 08-27-2008, 06:35 AM   #5 (permalink)
RK05's Avatar
RK05 wants to know Dino or Syn?
By any chance did you wash your bike before this happened? I had a similar problem and thought it was the sensor. Bought a new one and still had the problem. Turned out that the cable connection between the PC/factory harness got water in the plug. Once that was dryed out it was back to normal.
05' FLHRI
95", 9.8:1 W/Heads by BigBoyz, 37G's, Arlen Ness A/C, PC USB, Supertrapp Supermeg 10-disc open cap
RK05 is offline   Reply With Quote Quick reply to this message
Old 08-27-2008, 07:41 AM   #6 (permalink)
sounds like another dead PC3. borrow a friends PC just to see if both cylinders run.
dynojet never gave me any static about returning for warranty.
Old 08-27-2008, 07:42 AM   #7 (permalink)
Thread Ender
Pikeslayer's Avatar
Same thing happened to me.
2007 Street Glide
Old 08-27-2008, 09:01 AM   #8 (permalink)
SVD999's Avatar
No It Is A Used Pciii First Time I Tried It
Old 08-27-2008, 09:07 AM   #9 (permalink)
SVD999's Avatar
YEAH THATS MY THOUGHT, PCIII IS USED FIRST TIME I TRIED JUST TRYING TO COVER THE BASES BEFORE I GET ANOTHER ONE I COULD ALWAYS JUST TRY THE SENSOR IT WOULD NOT BE A BAD IDEA TO HAVE A BACK UP
THANKS
