For those who haven't been able to access the previous link, here's the inspection procedure on '03 Softail:
Firstly, you need to take off the front exhaust, to get at the cam box. Stuff an oily rag in the port, to prevent nesting birds, mice, etc. from taking up home there.
Next, fit a polythene sheet between the lower half of the cam box and the lower frame rails, and shape it to form a trough that will direct oil to your drain can. There is always some residual oil left in the cam box, and it's enough to make a big mess.
Slacken the cam box allen bolts a little at a time, in a diagonal sequence (to prevent distortion) then remove completely. If you leave the top two until last, it stops the cover falling off until you're ready. Congratulate yourself on your forethought, as a pint of dirty oil streams down your polythene into your ice cream box.
This is what the inside of the cam box looks like. There is a cam plate, which supports the outer shafts of the two cams, and houses the main oilways to and from the oil pump. The small gear from the crankshaft drives the rear cam, and behind the cam plate, there is a secondary chain, where the front cam is driven by the rear cam. Unless you have X-ray vision, or are a Venusian with eyes on flexible stalks, you can't see that.
The primary cam chain is tensioned with a spring-loaded shoe, bearing on the outer faces of the chain.
To inspect the shoe properly, you need to overcome the tension on the spring, and pull the shoe away from the chain. Having done that, you can fit a retention pin to hold it in place.
I bought the special tool from Jims, which comprises a special socket and the two retaining pins.
Having used it, it's an overkill for this job, but as you have to be really careful not to let the tensioner spring back on to the chain (which can take your finger off, or shatter the shoe) and it's needed if you ever do a cam or cam bearing change, I thought it was worth buying.
The instructions are not good, and it's not clear how the unloader is supposed to fit on to the shoe. It will go on two ways.
There's a bit of metal that extends out to the hexagon drive flats, and that's supposed to go below the lower right of the shoe. You need a huge 1 1/4" socket or wrench to rotate the tool.
Once you have rotated the shoe anti-clockwise, the hole in the tensioner will align with the hole in the cam plate, under the 'H'.
Push one of the pair of retaining pins in the kit through the tensioner, and into the hole in the cam plate.
Now you can inspect your shoe, which needs replaced if more than half the thickness is gone.
As you can see, mine looks pretty much OK (this was 6 years ago at 27,000 miles).
It would be easy to say, "Well, the outer one's OK, so the inner one will be too." but many have had perfect outers and wrecked inners, so that's not a good short cut to take...
Get down to your local drugstore, and buy yourself one of these:
I was looking for a simple, cheap mirror, but they were out of stock, and I spotted this illuminated one. Best thing since sliced bread, because it gets over the problem that most of us don't have three hands for the torch, the tool and the mirror...
The tensioner sits behind the cam plate, and its axle is shown under the yellow ring. The red ring shows the hole where the retaining pin fits.
Using the mirror, you can locate the two hooks on the tensioner. These are what the retaining pin fits through when the tensioner is disengaged, so you slip a sturdy and long flat bladed screwdriver under the rear one, lever it up, and then stick the retaining pin through until it supports the tensioner under the outer hook.
Push the pin in as far as it will go, then remove the screwdriver and push the pin through the rear hook, to secure the tensioner.
This is what it looks like inside:
With the tensioner secured, you are free to use the mirror to inspect the underside of the shoe, which looks pretty good on mine.
When you're finished, get the mirror in there again, and support the tensioner again under the rear hook. Keeping it supported, withdraw the retaining pin, and gently lower the shoe back on to the chain.
Degrease and clean the outer cam cover, remove old gasket, and clean faces. Fit new gasket, replace cam cover, and torque down the allen bolts in the sequence illustrated in your service manual.
