Upgrading to the 1987 and later release assembly will help greatly. You will have to change the bearing door and the outer cover, plus the 2 ramps 3 balls etc. And use the later model clutch cable. It's well worth the time and expense, change the release bearing while you are in there
i see, i was thinking about doing it, i found out by the gasket that it can be done(84-86 vs 87-up) and i need to replace the bearing cover.
now i'm not sure what clutch i have, the early or late 84 style, is there any advantage on the diaphragm spring? or to leave it there?
thanks for the help.
To identify the clutch. Remove the derby cover. You will see 4 10mm bolt heads, that is the late 84 clutch, or, If you see a plate with 10 coil springs under it and 3, 5, or 10, 9/16" head nuts it's the early clutch. The clutch should not matter when you do the update on the other side of the transmission.
To upgrade you will need every part from the right edge of the transmission case outward, including a new clutch cable for a 1987, it will all be bolt on, mods.
I special tool, a puller for the right side bearing door, it removes the door without disassembling the transmission, it is available from the sponsor, Georges garage.
Tanks for the info!
I think you didn't understand me right, Is the diaphragm spring have advance on the coil spring? Or just changing to "ramp and ball" will be enough?
Are all 5 gear housing are the same?(twin cam will fit?)
Or I need only evo/touring one?
Hello, Al, the step by step seemed long winded, and well, just long, lol, it was like reading a book. If it would be helpful to someone I can relist it.
All the 5 speed cases are basically the same, there have been some exterior changes over the years, a couple of main shaft changes, and a drive gear set change in the mid 90's and a larger main bearing in the late gearboxes, but the right side components can be changed rather easily to the late model actuator, it just needs all the parts to be changed to the later parts, nothing can be reused.
Yes, I did misunderstand. Actually, the 84-89 diaphragm clutch is the weakest clutch harley has ever used, it has fewer plates. The hub is prone to cracking. Honestly, I've never tried to go backwards and use the early clutch in the 84 up housing.
The best thing that can be done for the 84-89 clutch is the reinforcement ring for the hub and a complete rivera pro clutch.
Disconnect the cable from the lever, then check the lever. If it's shaft wobbles in the end housing, you might as well make the change over to the ball and ramp end housing. If it's still a good fit and it will turn smoothly, put a new cable on it.
Hi sorry for the delay, the cable handle pin and all are good, every thing works smooth, but still the clutch is hard, I notice that the most when staying on 1 gear on a trafic stop.
After I'm going on to a ride on my other bikes i got the feeling like the clutch is not connect to noting, it is just working without force.
Now I will try to get a used part for it, I was thinking on milling a shovelhead clutch cover with +87 style ramp and ball on it.
What do you think?
No I don't plan to take an old style cover and try to fit a ball and ramp inside, I will mill it from a solid block of aluminum. It won't be that hard to do.
I just need to get a new style cover for ref.
It could be done, but why, since you already will need a cover, for reference, and all the other parts, buy the door and bolt it all on????? Or if you just want to do what you want to do, I understand that also, nothing is hard, you just need the raw materials, and the tools to accomplish the task. Good luck, and maybe a few pics when you are done
Hi, if I will mill that cover I will only need to buy the clutch cover and won't need the door(?).
The small cover can be found for almost noting. Also I won't need to take the door out and to dill with it.
I can also customize the cover as I want.
I have the tools and acsees to cnc machine so it won't be a problme.
I understood that the 21 deg is better then the 18 deg, am I right?
If the 18 deg will work ok I prefer it for easy operation.
Just a note on cables - that flat wound outer cable can slip and bind under pressure. It will look perfectly usable, but don't trust a visual inspection. Amitix, I have an 84 flhtc with the early clutch hub like yours. It's easy to pull in - I'd be looking for the faulty parts before thinking about changing the whole design.
Related Threads
V-Twin Forum
2.7M posts
146K members
Since 2001
