Johnson Engineering Twist Gear : V-Twin Forum: Harley Davidson Forums
Old 01-23-2013, 03:24 PM   #1 (permalink)
djl
djl's Avatar
djl is on a distinguished road
I haven't seen any recent inquiring posts on the
http://twistgear.net/
but do recall a few inquirys about this modification a long while back. Just wanted to let any interested members know that I have completed the install in my '02 FLHT so, if there are still any inquiring minds, post away.
djl is offline   Reply With Quote
Old 01-25-2013, 09:17 AM   #2 (permalink)
Dogbone96 is on a distinguished road
What is your opinion of this gear set? Is the gap between 4th and 5th very noticable? I have a Twist Gear set here at the shop and have been thinking about installing it in my '06 Ultra. I like the 3.15 high gear but could use lower 1st thru 4. Any comments good or bad are appreciated.
Dogbone96 is online now   Reply With Quote
Old 01-25-2013, 12:10 PM   #3 (permalink)
djl
djl's Avatar
I have never thought a six speed conversion was worth $2500 (Baker) and five speeds is enough for me. I would do it again in a heartbeat; very cost effective upgrade IMHO. I do notice the gap in the 4-5 shift but have no issue with it. By the time I hit 5th, I am always going fast enough that I don't notice the gap. I do find that I use 3 and 4 more in the twisties than before which is changing that riding style a bit but for the better; less braking and more evenly applied power.
The parts are quality. 2000 miles since the conversion and, shor of a six speed, a great upgrade for the five speed. You will need to recalibrate your speedo as it will be off 10%.
Old 01-25-2013, 02:54 PM   #4 (permalink)
Thank you, It looks like a good spring project. I have all the 5 speed tools so it will be a simple job. I have a 24/37 primary set I could install but didn't want to lose the tall 5th. The Twist Gear looks like the best of both.
Old 01-25-2013, 08:42 PM   #5 (permalink)
djl
djl's Avatar
Good luck. If you have all the tools and parts laid out and don't run into any glitches, it's a Saturday job.
