I am trying to remove the transmission drive pulley. I understand you go clockwise with the threads. I have used a breaker bar, impact wrench and I can not get it loose. Any other suggerstions?
It is a 94 low rider.
The 6 speed in the 09 & 10 trikes I swapped transmission pulleys/sprockets on where removed by loosening them counter clock wise. Even then they are a bitch to loosen up.
2012 GL1800... Seeing how the other side lives.
