09 gear set : V-Twin Forum: Harley Davidson Forums
Old 11-19-2012, 09:56 AM   #1 (permalink)
jbxmn's Avatar
jbxmn is on a distinguished road
09 gear set
Does anyone know it a 09 Ultra gear set will fit in a 00 FLH transmission?
jbxmn is offline   Reply With Quote
Old 11-20-2012, 05:02 PM   #2 (permalink)
jbxmn's Avatar
I can't believe. No one on this forum knows the answer to this question? Or is it a dumb question? If its a dumb question, tell me.
Old 11-20-2012, 06:51 PM   #3 (permalink)
Dan89FLSTC's Avatar
No, you are out of luck on that one...
The `00 transmission is a 5 speed.
The `09 is a 6 speed.
Different configuration transmissions altogether.
Not a dumb question.
Old 11-21-2012, 01:47 PM   #4 (permalink)
jbxmn's Avatar
Thanks; I was hoping I'd get lucky and the case would be the same. I need to replace my six speed gear set in my 00 FLHRI.
There is a six speed gear set from an 09 on ebay for 300 bucks.
Old 11-21-2012, 03:11 PM   #5 (permalink)
LoneEagle964's Avatar
LoneEagle964 is on a distinguished road
If you have a 6 speed on a 00 then it is most likely an aftermarket unit since I do not know of any original 6 speeds before the 06 dyna , you may want to check it because you may have to use a gear set specific to the manufacturer .
LoneEagle
LoneEagle964 is offline   Reply With Quote
Old 11-21-2012, 07:53 PM   #6 (permalink)
mgb939's Avatar
mgb939 is on a distinguished road
LoneEagle
Harley made a 6 speed overdrive SE transmission I believe in 2000, it was in the P&A cataloge for years. I had one in my '04 Ultra.
2009 FLHTCU A Black Ultra Classic
HD Tall Boy Seat
Ness Big Sucker A/C
V&H Slip-ons
V&H Fuel-Pak
Stage 1 HD Download
HD Oil Cooler
HD Oil Temp Gauge
Soos 1" floorboard ext.
mgb939 is offline   Reply With Quote
Old 11-21-2012, 07:56 PM   #7 (permalink)
Enjoying a great Ride.
jeffsglide's Avatar
jeffsglide is on a distinguished road
I had one in my 05 dyna, and 06 Roadglide also.
jeffsglide is offline   Reply With Quote
Old 11-22-2012, 08:12 AM   #8 (permalink)
Dan89FLSTC's Avatar
The only 6 speed gearsets that will work in your bike are the aftermarket 6 speed units designed to fit the 5 speed transmission case.
