shifter shaft splines and shifter : V-Twin Forum: Harley Davidson Forums
Old 11-04-2012, 07:47 PM   #1 (permalink)
dortiz64's Avatar
dortiz64 wants to know Dino or Syn?
just wanted to share a slightly unpleasant moment as i was on 6th gear doing close to 75MPH and was getting ready to down-shift and my toe shifter (streetglide) was sitting on the floorboard....Moral of story is be sure you tighten that allen bolt when you do the routine maintenance on the bike....it appears the vibration of the engine will wear the splines on the shaft (driveline)that the shifter attaches to....I manage to downshift by using the toe of my boots to edge up the toe shifter upwards to lower the gear and move to a safe spot and then schwartzernegger the toe shifter enought to get me home....it would not tighten enough to keep it in place and kept falling until i had the shifter and the shaft replaced under the extended warranty
2014 CVO Limited, Vance Hines, SERT
2015 Dyna Low Rider
dortiz64 is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 07:55 PM   #2 (permalink)
webco2 wants to know Dino or Syn?
Thanks for the warning.
webco2 is offline   Reply With Quote Quick reply to this message
