4 or 5 friction disks : V-Twin Forum: Harley Davidson Forums
Old 11-03-2012, 11:54 AM   #1 (permalink)
slater555 wants to know Dino or Syn?
I have a 1953 FL when i see clutch pack kits for 1941 to 1984 they include 5 friction disks and 4 steel disks but the description says 1941 to 1964 used 4 friction disks and 3 steel disks. Now I have been told that the old set of 4 friction and 3 steel was the same size as the new 5 friction and 4 steel (about 1.5+ inches). So I am trying to figure out whether I need to use 4 or 5 friction plates. So anyone know the clutch stack height for a 1953 FL or any other useful information. it is kick only, 4 speed, chain primary, dry clutch.
thanks
slater555 is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 09:29 AM   #2 (permalink)
4 or 5 friction discs
Really... no one?
Old 11-04-2012, 09:49 AM   #3 (permalink)
59panhead wants to know Dino or Syn?
I have been running 5 f and 4 steel D in my 59 put em in do the adjustment and see how they work!
you might make a stack and measure how thick the new ones are and do the same to the old set up if its close you should be good!
59panhead is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 05:35 PM   #4 (permalink)
thanks ill do that
