86 FXR trans updating? : V-Twin Forum: Harley Davidson Forums
Old 10-29-2012, 06:02 PM   #1 (permalink)
CMaD is on a distinguished road
I am wanting to update the old tappered shaft transmission in my 86 FXR. Was wondering if anyone on here has done this before and/or has any info on doing this, ex.. can i keep my trans case and just swap internals? whats the best year parts to look for? can i use my inner and outer primary cases? any info will help.
CMaD is offline   Reply With Quote
Old 10-29-2012, 08:01 PM   #2 (permalink)
omgtkk's Avatar
omgtkk is on a distinguished road
This winter I'll be doing something similar; I'm installing a Baker OD six in my '86 FXRD. To go from tapered shaft to splined you will have to get new tranny internals with the splined mainshaft and will also have to replace the entire clutch assembly with a later model assembly with splined keyway. I believe '89-91 would be a drop-in. I'm going with a Baker SP8 complete unit, but that is just my preference.
Tranny case and your primary cases should be fine. I'm not positive if your lever actuated clutch arm will be compatible or not. I recommend dumping it for a ball and ramp right side cover. I picked one up on Ebay for $40. Rumors have it that the actuating finger on the stock '86 set-up is a real weak spot.
omgtkk is offline   Reply With Quote
Old 10-30-2012, 04:44 AM   #3 (permalink)
Dan89FLSTC's Avatar
No problem just swapping internals, any 5 speed gearset will fit into your case.
`90 or later will have a splined mainshaft.
If you use a `90-`93 clutch your primary and starter gears will remain the same.
Old 10-30-2012, 06:32 PM   #4 (permalink)
why was this moved, it is bike specific having to do with a FXR?
Old 10-31-2012, 04:40 AM   #5 (permalink)
Dan89FLSTC's Avatar
It is not bike specific, this information applies to all 5 speed HDs...
Old 10-31-2012, 06:21 AM   #6 (permalink)
This does not apply to TC 5 speeds nor softail 5 speeds, thanks for all the help, I'll get my info elsewhere.
Old 10-31-2012, 06:02 PM   #7 (permalink)
Dan89FLSTC's Avatar
The information I gave you applies to all 5 speeds in all big twins.
Softail, Bagger, FXR, Evo or TC, 5 speed transmission guts are interchangeable.
But feel free to get your information elsewhere.
Old 11-01-2012, 02:16 AM   #8 (permalink)
Krowbar is on a distinguished road
They moved one of my post to that was pretty FXR specific. Just roll with it.
1972 Superglide FX: Rebuilt, Super E, Drag pipes (FOR SALE PM ME)
2005 Sportster 1200: Thunderheader, SE ICM, SE carb upgrades, pretty stuff
1985 FXRS-SP: (looks VERY different than the pic. More black now) Dyna 2000 ICM, Twin Tec II Single Fire, Mikuni 42mm, S&S intake, Progressive springs, need money for Thunderheader and mid-controls! Have lot's to trade and $ if you have one for my bike!
Krowbar is offline   Reply With Quote
Old 11-01-2012, 07:16 AM   #9 (permalink)
I am rolling with it, to other forums to get my info. Not impressed with this forum at all and most likely wont be back. Some people on here think they know stuff but clearly dont.
Old 11-01-2012, 07:06 PM   #10 (permalink)
Viel Vergnügen
vindex1963's Avatar
Temper temper.
You were given good information.
Not coming back is OK.
2004 Victory Vegas
2009 Ultra
Old 11-03-2012, 01:29 PM   #11 (permalink)
JLH
JLH is on a distinguished road
I have use of this thread. I have an 87 FXLR that I would like to upgrade as well. I just have to get going with the upgrades and begin the search.
JLH is offline   Reply With Quote
Old 11-03-2012, 04:37 PM   #12 (permalink)
Dan89FLSTC's Avatar
Lots of folks here ready to help you out.
Old 11-06-2012, 07:49 AM   #13 (permalink)
mark p's Avatar
mark p is on a distinguished road
Man was he touchy.Let's see FXR, short temper, does not trust others, must be HA. Come on back when you cool down brother we are here to help.
mark p is offline   Reply With Quote
Old 11-10-2012, 07:17 AM   #14 (permalink)
Dan89FLSTC's Avatar
I couldn`t figure out why he even posted a question when he already knew all the answers...
Old 01-28-2013, 05:41 PM   #15 (permalink)
hbever is on a distinguished road
I am still wondering about the # of teeth for the starter gear remaining the same between an 86 and a 90. The 86 starter clutch is external and is moved by the lever and external solenoid system. A 90 has internal clutch and solenoid with jackshaft system. So far the only responders have 89s which are similiar to 90s in the starter system. Some one doing an 85 or 86 has ALOT of differences to overcome. Does a 90 clutch bolt into an 85 if all you replaced was the keyed mainshaft with a splined one? Absolutely no other mods required? My 85 starter clutch will mesh perfectly with a 90 ring gear? That is the juice we all desire!
hbever is offline   Reply With Quote
