Inner Primary Bearing Race - how to remove without the tool : V-Twin Forum: Harley Davidson Forums
Old 01-16-2010, 01:52 PM   #1 (permalink)
BigMike's Avatar
BigMike wants to know Dino or Syn?
I just replaced my shifter shaft seal and I'm installing a chrome inner primary. I bought the Baker Hi-Torque bearing for the inner primary. First I have to remove the race from the transmission shaft.
Any thoughts?
2002 Road King
95" - HQ0034 cams - Big Boyz Street Port - Rinehart TD SERT
92HP/102TQ
Paint By Attitude Custom Painting
BigMike is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 01:57 PM   #2 (permalink)
ironheadbuck's Avatar
ironheadbuck wants to know Dino or Syn?
get the tool and save the shaft -you can sell it or just borrow one
02 roadking-lv it
73 xlch
07ducati 1098s traded
2011-1198sp ducati
trek 6500
no helmet or training wheels
favorite weapon-colt 45 gold cup stainless
http://s39.photobucket.com/albums/e179/threebuck/
ironheadbuck is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 05:06 PM   #3 (permalink)
Thread Ender
Pikeslayer's Avatar
I used a dremel and scored a deep groove in the race. Be careful not to go through the race into the shaft. You only have to go 1/2 way through then tap it with a chisel.
2007 Street Glide
Old 01-16-2010, 05:19 PM   #4 (permalink)
BigMike's Avatar
That was the approach I was thinking of taking.
2002 Road King
92HP/102TQ
Old 01-16-2010, 08:11 PM   #5 (permalink)
Premium octane member
TXCHOP's Avatar
Done it many time like that with no problems. When the race walks in to the seal, you have no choice but to cut. I use the dremel with a cut off wheel. Takes a bit of time, but doesnt cut fast and is accurate. Cut 1/2-3/4 through it and take a chisel and a hammer and tap, it should split.
S&S T124
Old 01-16-2010, 08:50 PM   #6 (permalink)
well i did it that way and had to buy a main shaft -im sort of blind
02 roadking-lv it
73 xlch
2011-1198sp ducati
trek 6500
Old 01-17-2010, 03:03 PM   #7 (permalink)
BigMike's Avatar
Piece of cake - 5 minutes
2002 Road King
92HP/102TQ
Old 01-17-2010, 04:17 PM   #8 (permalink)
glad u got lucky -mine was up in the bearing -i used a dremel to split it -was froze solid -tried to cut more -nicked shaft -didnt want to take a chance so i replaced main shaft -
02 roadking-lv it
73 xlch
2011-1198sp ducati
trek 6500
Old 01-17-2010, 04:19 PM   #9 (permalink)
just a thought but i would take pully off and replace quad ring and seal while i had it that far apart
02 roadking-lv it
73 xlch
2011-1198sp ducati
trek 6500
Old 01-17-2010, 06:43 PM   #10 (permalink)
BigMike's Avatar
Yep, already have the Cometic seals. Borrowing the tools this week. Should have everything buttoned up next weekend.
2002 Road King
92HP/102TQ
Old 01-17-2010, 11:29 PM   #11 (permalink)
TXCHOP's Avatar
S&S T124
Old 03-08-2010, 05:49 PM   #12 (permalink)
BrokenStroke wants to know Dino or Syn?
This is very cool. Thanks Guys! But I still have a question. The OEM outer race is press-fit into the inner primary, and the OEM inner race is press-fit onto the mainshaft, so one of these must not be a press-fit on the new bearing or we wouldn't be able to just put the inner primary back on? Am I missing something?
1999 Dyna FXDS
TC88
SE A/C (K&N)
40mm CV w/Dynojet Kit
SE Racing Slip-ons (modified)
SE 6200 Ignition
SE-204 Cams
SE Quick-Change Pushrods
Torrington Bearings
Stock Heads & Jugs
Progressive 412's, SE Fork Brace
83.56 HP(SAE) 91.17 FT/LBS
BrokenStroke is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 08:50 PM   #13 (permalink)
1993FLHS wants to know Dino or Syn?
If installing the Baker bearing, it's pressed into the primary. The inner race of the bearing slides on the mainshaft when installing the inner primary.
1993FLHS is offline   Reply With Quote Quick reply to this message
Old 03-09-2010, 12:40 PM   #14 (permalink)
OK. I kinda guessed that would be the case. Cuz the primary side is pressed and set between two retaining rings. I need to go in and change the mainshaft seal and don't want to get stuck on something stupid. Weather's starting to get nice, ya know?
Speaking of seals, I know 3-4 other guys that have the same leak. Are there any better mainshaft seals or kits out there? Maybe Cometic or somebody? One guy had his fixed at the stealer and it was leaking again 3 months later. I wouldn't mind replacing a $2 seal all the time if it was a 10 minute job!
1999 Dyna FXDS
TC88
SE A/C (K&N)
SE 6200 Ignition
SE-204 Cams
Torrington Bearings
Stock Heads & Jugs
Old 03-10-2010, 08:02 PM   #15 (permalink)
I'm putting Cometic seals in mine. Fab'ed a bunch of tools from various pieces of PVC for the install. For the mainshaft seal get a 3/4" coupling from Home Depot for .35 cents. File flush the shoulder from the inside so it'll fit over the splines. Grind off about
.045" of material about 1/4" from one end so the coupling will push the seal inside the main gear. Tap in the seal with the coupling using a 15/16" deep well socket. Worked pretty good. Beats spending $$$ for a tool hopefully I'll only use once.
For the main seal get a PVC 3" to 2" inside bushing / adapter. Again file the inside shoulder so it will clear the main gear splines. The seal starts easy in the case by hand. Use a piece of 2" PVC to send it home.
