swap from 5 to 6 speed?? : V-Twin Forum: Harley Davidson Forums
Old 11-20-2009, 10:46 PM   #1 (permalink)
Deafautotech wants to know Dino or Syn?
i own 2003 Harley Road king classic with 29,100 miles, it has 88" twin cams engine as had better low end torque performance as it is scream between 2,000 to 3,800 rpm. i never run my harley over 4,000 rpm for no reason. BUT i am ask for your opinion or advise that i am considering about swap from 5 speed transmission for 6 speed transmission that i can only swap the gearset... good idea or ???
Most of mileages are highway. so i think 6 speed transmission can help engine as little better MPG on highway but reduce the rpm as 200 to 400 rpm depend on gear ratio...
I will do all works myself if good idea to do 6 speed swap???
for Sample from Ultima Product:
http://www.ultimaproducts.com/6spdbuilder.htm depend who or where to buy: 400 to 600 dollars.
i know Baker transmission are great as strong and great warranty BUT out of my budget... 2,000 dollars
I am thinking about bump from 88" to 95" but i am not sure because 88" engine run good and no problems. so i just want let engine stay same thing until it need rebuild...
Deafautotech is offline   Reply With Quote Quick reply to this message
Old 11-28-2009, 09:09 PM   #2 (permalink)
1997bagger's Avatar
1997bagger wants to know Dino or Syn?
I have looked into the Ultima builders kit and havn't heard any negatives towards the budget build, I"m a little concerned about the higher 1st gear ratio and loaded, something you might research with the big bike. Many factory 6 speed owners are dropping a couple teeth (search "32 teeth") on the drive sprocket to make 6th gear a little more user friendly and have the same overdrive ratio as Ultima, Baker changes the drive ratio in it's kit, some items I have started weighing in.
1997bagger is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 08:19 AM   #3 (permalink)
Coolmaker's Avatar
Coolmaker wants to know Dino or Syn?
88" is a little light in power to pull the 6th gear IMHO, I did it and had to increase power, Baker makes a good tranny, I have the DD6, and used it with the 27 tooth comp gear. Works GREAT..
Coolmaker is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 08:27 AM   #4 (permalink)
0043--Licensed to Doof!
Geezer-Glide's Avatar
Geezer-Glide wants to know Dino or Syn?
The screamin eagle 6 speed is not an overdrive tranny, but the Baker DD6 is. I don't think you need a 6 speed with a stock or near stock 88 incher.
Two things to think about....
If you go 6 speed and don't like it, you can not reverse the Screamin' Eagle and put the 5 speed back in because you have to drill out one of the bearing bosses in the tranny case for a larger bearing.
If you put in a Baker DD6 and don't like it, just take it out and put the 5 speed back in. There are no case modifications.
Seat, frame, stroker motor, paint, some chrome, two wheels, tires, road grime and a couple of old dead bugs. Fun meter.......PEGGED!!!
I Doof, therefore I am.
D.F.F.D
Geezer-Glide is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 08:31 PM   #5 (permalink)
doc ock wants to know Dino or Syn?
After talking to an Indy I goto, a 6 speed is pretty much not worth doing. HD engine are built to run at 3000 rpms all day every day without problems. My Indy talk with Baisley and stated that if you run a motor below 2700 rpms with a 6 speed and twist the throttle you will lug the motor. So with that I saved my money and stayed with the 5 speed. Unless you run over 70 mph all the time I wouldn't do it. My bike 70 mph = 3000 rpm's which I rarely go over. I think this info is to be true because I was willing to spend money and the shop talk me out of it.
doc ock is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 09:35 PM   #6 (permalink)
Coolmaker's Avatar
Actually the DD6 is a direct drive trans, with 6th being direct and not over driven. It gains the ratio by over driving the primary.
Old 12-17-2009, 12:49 PM   #7 (permalink)
Barney Biker wants to know Dino or Syn?
I have two riding buddys that went to the 6 speed trans.. Both 88 engines.
Both wish they had never done this. Don't like them.
Barney Biker
07 EG
Barney Biker is offline   Reply With Quote Quick reply to this message
Old 12-17-2009, 12:51 PM   #8 (permalink)
Skywarrior's Avatar
Skywarrior wants to know Dino or Syn?
Tell them to go to 95" and it will make a real differance.
Skywarrior is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 08:34 AM   #9 (permalink)
Coolmaker's Avatar
Or 103"..
Old 12-19-2009, 12:45 PM   #10 (permalink)
kennyflhr's Avatar
kennyflhr wants to know Dino or Syn?
I like mine
I have a 98 Road king with an S&S 6 speed & I love it. The motor is 80" ( blew up the 89" stroker!!) with 10:1 wiesco pistons, woods 6 cam (Thanks scott!!) S&S "E" carb & thunder header. Nothing special , & I have no problem pulling the 6 speed. The S&S trans. is 1:1 final drive with a 34 tooth pulley. Check out the gear ratios on thier web site & you'll see That even with the larger pulley, the 1st 5 gears are lower than the stock 5 speed & 6 has about a 200 rpm drop at 80 mph. 1st gear is real deep & is perfect for the bagger, real close ratio, no huge rpm drop between gears. The only draw bvack is all the case mods. Took me a day & 1/2 to put it in! Between the final drive ( trans. comes with light wieght 34T pulley) & primary choices, surely you can find a ratio that is perfect for your needs. Shifts smooth as silk & tough as nails. I love it & would never go back to the 5 speed, but if I wanted to, just put the stock 32T pulley on & 6 is stock 5th. Good luck.
kennyflhr is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 04:57 AM   #11 (permalink)
semi-retired
FatBobRob's Avatar
FatBobRob wants to know Dino or Syn?
seems like every week..........................
Just got an e/m from Baker.Looks like all their trann"s are on sale this week.
I can't means I won't!
FatBobRob is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 08:23 AM   #12 (permalink)
dont do it! you have a very strong tranny and the ratios are really good for town. on the highway, you run right around peak tq for most mild builds.
Old 12-26-2009, 06:00 PM   #13 (permalink)
2000FiveOh wants to know where he is and how he got here
If you plan on staying stock it really depends on your primary gearing. A stock 88 incher with tall gears, I wouldn't do it. You'll end up shifting back and forth from 5th to 6th all day. You'll either need a nice jump in power or different gearing to get what you want out of a 6th gear. I run 3:37 primary gearing and would love to run a 6 speed with those gears. Best of both worlds!
BTW where did you see the Ultima set up for $400?
2000FiveOh is offline   Reply With Quote Quick reply to this message
