Dan Vance RacingMotorcycle.comSportbikeTrackGearRRcycles.comMotorcycle-Communication
CycleGear.comLeslie Kay'sProCharger.com
JardineProducts.com
CycleGear.com
Old 10-29-2009, 01:55 PM   #1 (permalink)
I ain't right
TERMINKNOTTER is on a distinguished road
Primary drain plug thread size
Anyone know what size the drian plug tread is on a 01 touring bike ? The plug on my girls Road King doesn't seem to thread in as far as it should. Want to chase the threads but would prefer to have the tap on hand, save the trouble of running out to get it.
TERMINKNOTTER is offline   Reply With Quote
Old 10-29-2009, 02:08 PM   #2 (permalink)
springer-'s Avatar
Are you asking about the primary or the oil pan? If the oil pan, this might help ... http://www.bigboyzheadporting.com/showthread.php?t=85 They make oversize plugs to repair a stripped out hole.
207-621-8089
Old 10-29-2009, 04:07 PM   #3 (permalink)
hbmc's Avatar
measure the thread size of the plug??? use a die to thread it on and use the corresponding tap to chase it thru
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
Old 10-29-2009, 11:49 PM   #4 (permalink)
Retired Navy - MCPO
Ed Y's Avatar
Primary drain plug on an 01 is a pipe thread. It's not designed to thread all the way in. If I remember correctly, it's a 1/8 pipe thread.
Ed Y
2002 FLTRI
I yam what I yam.
Old 10-30-2009, 08:11 AM   #5 (permalink)
I ain't right
Primary drain plug.
On my 03 RKC plug screws in pretty far, service manual spells out amount of plug to leave exposed. On her 01 RK, manual doesn't give any info, and the plug doesn't seem to go in far enough. Was leaking, seems to have finally stopped(after aweek or two and 1000 mile road trip).
Just don't want to screw it in too far. Thought the treads might be buggered up. This is the first I've done any work on her bike.
Old 10-30-2009, 08:52 AM   #6 (permalink)
LADave is on a distinguished road
Originally Posted by TERMINKNOTTER View Post
Primary drain plug.
If it just stopped leaking on its own, first thing I would do is check the fluid level in the primary. Make sure there's still plenty in there. These things don't just heal themselves...
On to the drain-plug...
First, you might just pull it out and give it a visual inspection to see what kind of condition its in (this will be a good time to change the primary fluid) If the threads on the plug are boogered up, compare it to the closest tap you can. Either 1/8-inch NPT or maybe something else, and go from there...
If nothing is boogered up, you can coat it with a dab of pipe-dope or put a few wraps of Teflon tape around it or even a very small dab of silicone. I emphasize "Dab" because a lot of people like to really goop on the silicone. Don't make that mistake. A very light coating on the first few threads should be more than enough.
I don't know if is a pipe thread or not. But, if it is, they are tapered a bit. Tightening it up a bit, shouldn't cause problems. Not unless you go crazy with it and strip the threads.
When I have to R & R the primary cover, I tighten it, until it feels snug. If that don't keep it from leaking, Tape, pipe-dope or a dab of silicone, which ever is handy...
Everyone wants to go to heaven,
Nobody wants to go now...
1987 FXRS-SP
.005" over 80-Inch, Andrews EV27 Cam
S&S "E" Carb - Ultima Single Fire Ignition
Manley Stainless Steel Valves & Crower Springs
Ultima Single-Fire Ignition
2-into-1 pipe (might be an LSR)
LADave is offline   Reply With Quote
Old 10-30-2009, 02:01 PM   #7 (permalink)
Retired Navy - MCPO
Ed Y's Avatar
I always use "thread sealant with Teflon".
Ed Y
2002 FLTRI
I yam what I yam.
Old 10-30-2009, 02:20 PM   #8 (permalink)
hbmc's Avatar
yep that is right.... Now I think about it--- it is designed to snug up in there with some teflon tape. And so need to be replaced every so often as the threads are designed to collapse before the cover does.
1991 flstf 'fat-boy
2-1 White "E-pipe"
