Weeds,
You'll do fine fixing this yourself if you listen to the major members here. I had this exact problem. I didn't get to the bottom of it until I scrubbed the leaky area clean with hot soapy water, then dried it, then took a short ride to determine the source. You need to do this. This is how I determined I had an inner primary seal leak. That's my project this winter. Good luck.
2007 Street Glide
