Which shifter pawl?
Hi all. Shifter shaft lever splines were worn out. I thought it was just the lever, but closer inspection revealed that the splines on the shifter shaft are worn down a bit too.
1996 FXDS, 40K miles, not far from stock. Not a high hp scoot by any measure.
Question is, which replacement? Factory, Baker, Sputhe, Jims? I don't plan on replacing the shift drum unless I find a problem with it, just the shifter pawl. First time into one of theses beasts.
Tnx..
