Dan Vance RacingMotorcycle.com
Fuel MotoProCharger.comRRcycles.comMotorcycle.com Classifieds!
JekillandHyde.eu
Old 10-04-2009, 06:31 PM   #1 (permalink)
Baker High Torque Primary Bearing
Plan on a 107 this winter, and while there's not enough hp on this to really create problems on the pb, race walk could still be an issue. Since I'll be freshening up things anyway I thought of using the Baker high torque bearing and seal kit. Sounds good initially ,but since the oem race is removed the possibilty, should this bearing go for a crap, there is risk of scoring up the primary shaft. Second problem is the new seal rides directly on the primary shaft and over time could cut a groove in it reducing it's ability to seal. Knowing this, is it worth swapping or stay oem and hope the race stays put. Thoughts?
Ron
Old 10-04-2009, 08:40 PM   #2 (permalink)
Premium octane member
TXCHOP's Avatar
I have used the Baker product with great results in several bikes now. No worries from me, they work as advertised. If you are worried about all that, look into the S+S inner race. Has a lip on it to prevent it from walking in.
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
TXCHOP is online now   Reply With Quote
Old 10-04-2009, 10:54 PM   #3 (permalink)
Booggerbe's Avatar
Booggerbe is on a distinguished road
As TxChop says you cant go wrong with the baker bearing set up . Have used them on several builds and they work as advertised. Booggerbe
2006 SG 98" Hyperformanc/R&R/Axtell motor. 11.3 comp, remodified R&R billet heads, R&R cam plate, R&R 615/585 cams and gear drive. 1.675 Roller rockers, modified 07 oil pump, Reworked Hyperformance crankshaft, Axtell cylinders and pistons custom cnc by HyPerformance, Bob Wood Rebel carb, wood a/c, DTTT ign,Baker od 6 speed, Arnott air ride, pro-clutch, 3:37 gearing, 123.46hp / 119.01tq.
Booggerbe is offline   Reply With Quote
Old 10-05-2009, 01:13 PM   #4 (permalink)
Sounds good. I guess for that one in a million fluke where the bearing could seize and guall the shaft the stock race could be stuck back on to save it. I guess the Baker bearing is on my list.
Ron
Old 10-05-2009, 04:56 PM   #5 (permalink)
Site Sponsor
rosascycle's Avatar
rosascycle is on a distinguished road
H-D used the same sealed type bearing and seal from 1965 up to 1990's when the bearing and sleeve type came about.Not many ever fail we install about 30 to 35 sealed type bearings kit a year for the past 5 or 6 yrs as for the seal putting a grove in the heat treated main shaft I've never seen that, for the money the baker bearing kit is well worth it
PH: 631-424-4955
Huntington, New York 11743
http://www.rosascycle.com
rosascycle is offline   Reply With Quote
Old 10-05-2009, 05:21 PM   #6 (permalink)
Is this bearing sealed or just shielded?
Ron
Old 10-05-2009, 07:12 PM   #7 (permalink)
ironheadbuck's Avatar
ironheadbuck is on a distinguished road
just use it -yaaaa baker
02 roadking-lv it
73 xlch
07ducati 1098s
trek 6500
no helmet or training wheels
ironheadbuck is offline   Reply With Quote
Old 10-05-2009, 07:42 PM   #8 (permalink)
Never mind. I blew up a pic and see it's a shielded bearing, not sealed.
Ron
Old 10-06-2009, 06:07 PM   #9 (permalink)
SLPER's Avatar
SLPER is on a distinguished road
Skf
Ron
I used an SKF captured race bearing and seal $13cdn no problems.
Cheers
Feel free to stand in front!
SLPER is offline   Reply With Quote
Old 10-07-2009, 12:02 AM   #10 (permalink)
sportking is on a distinguished road
I dont really remember why .
But Doc suggested I didnt use the one I had bought .
What I do recall is that he said H D used that style in the past though
sportking is offline   Reply With Quote
Old 10-07-2009, 06:59 PM   #11 (permalink)
Well Doc, can you elaborate please?
Ron
