07 Ultra from cable to Hydraulic clutch
Any one know what parts I need to make this happen? The harley p/a catalog lists a screaming eagle 6 speed hydraulic clutch cover, will this fit on the oe 6 speed trans, is it the same trans? I guess I would also need to know whatever else is required other than mastercylinder and line....Want finish on hand controls to match right side controls (oe black brake master etc) and the diamond back brake lines i have. Dealer here is clueless.....
2007 Ultra
2007 Ultraclassic
Thundermax with Autotune
V/H dresser Duals with Supertrapp S/e slipons
S/e air cleaner
Andrews 26 cam as rec by Hillside
Andrews 30 tooth front belt pully
Bling, Bling, Bling
Oh where does the madness end....
