What is the correct HD P/N for the 24 tooth sprocket?
Can some one tell me the correct HD part number for a 24 tooth compensating sprocket for a 2002 Road King? I read in one of the posts that HD P/N 40269-85A was the right one. Can someone confirm this?? I don't want to crack my compensating nut loose only to find out that I have the wrong 24 tooth sprocket. I also read that Baker has a DD6-178 adjuster shoe that is larger than stock that will take care of the additional slack in the primary chain. Is this also correct??
Thanks in advance for your help!!
Bruggy55
