Motorcycle-CommunicationCustom Dynamics
JardineProducts.comProCharger.comFuel MotoMBO EnterprisesPro Pad
Old 09-17-2009, 04:17 PM   #1 (permalink)
FatOldBastard
Eclipse's Avatar
Eclipse is on a distinguished road
I'm not sure where to start
Hi all,
I was riding my 01 Ultra (with 6 speed gearset) a couple of weeks ago, I was slowing down for a intersection and downshifted and then started to accelerate and the bike made a strange clunk sound and it wasn't accelerating anymore. the bike was running but I coasted to a stop on the side of the rode. I shut off the bike and looked around to see if the belt broke or what else could be wrong and the only thing I could see was oil dripping from between the tranny and inner primary.
Once it was towed home and I got it on the lift I pulled the primary inspection cover and saw it had the proper amount of oil in it, I then drained the tranny and it was very low on oil.
I was wondering if someone has any idea what the problem could be.
Thanks for reading my rambling story.
David
Eclipse is offline   Reply With Quote
Old 09-17-2009, 11:09 PM   #2 (permalink)
BadWeather is on a distinguished road
Have you tryed putting it in gear since. I would try without the engine running and the bike on the lift see if you can shift through te gears.
06 CVO 113 Ultra
SE MVA Heads
SE 251
SE 50mm TB
SE 10.5:1
ThunderMax ECM
Zipper A/C
AIM 92T VPC
D&D Fat CAt
3.37 Final Gearing
BadWeather is offline   Reply With Quote
Old 09-18-2009, 12:09 AM   #3 (permalink)
The Anti-RUB
petrock's Avatar
Since the oil was coming from the tranny, and it was coming out on the primary side, I would guess it is the main shaft seal. You might have fried your tranny as indicated with the big clunk noise and lack of acceleration. Was there alot of metal shavings in the tranny oil?
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 09-18-2009, 07:41 PM   #4 (permalink)
FatOldBastard
Eclipse's Avatar
There were no shavings in the oil or on the drain plug.
Old 09-19-2009, 02:38 AM   #5 (permalink)
The Anti-RUB
petrock's Avatar
Well thats surprising yet promising. The low oil in the tranny may be a red hearing. If your tranny had grenaded, you would have seen metal in the tranny oil when you drained it.
However, I would definitely start doing some exploratory surgery. Start with the primary -> clutch -> then into the tranny. Lots of things could cause the symptoms you describe. So its kind of hard to narrow it down on the forum. Just take your time and you should find the problem fairly quickly. Good luck...
SE Stage-II 95"
My Two Front Teeph
Old 09-19-2009, 03:15 AM   #6 (permalink)
F$ck Google ads
ViennaHog's Avatar
Do you have power to the rear wheel? If so in all gears? Could be a busted main shaft that pushed the bearing out and along with it the mainshaft seal. As other said, some investigative surgery is on order.
2008 Ultra dark blue pearl
BigBoyz ported street heads
103" SE FT
0.030 Cometic HG
Woods TW 6
V&H Monster Ovals
SE ventilator a/c
TTS
SE compensator
SE race clutch
VPC 92 T
Magura hydraulic clutch
BaggerBrace stabilizer
Full floater front discs
After Douglas Adams RIP
ViennaHog is offline   Reply With Quote
Old 09-19-2009, 07:51 AM   #7 (permalink)
Premium octane member
TXCHOP's Avatar
Last season, i had a customer split 5th gear(cs) into 2 pieces. Did just as you describe. easy to pull the trans top cover off and take a look.
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
