09-14-2009, 07:34 PM
converting belt to chain
so i have my stock pulley setup is 32/70 so what in comparison would be the closet ratio to that in a chain i was thinking of running a 24 up front and have no idea what to run in the back, it is a 2003 road king. I also am wondering what offseet should the front sprocket have, they come in .500 or .900 the rear tire is only a 150.
thanks
09-14-2009, 07:52 PM
http://www.3guyz.com/index.php?optio...ples&Itemid=94
That link may help. I thought they also sold a conversion kit. I can't find it on the new website though. Might be worth a call.
2008 FLHTC, 103"
114ft/lbs Torque, 118 Hp
09-14-2009, 08:44 PM
Why, chains are a PITA?
2006 FLHTPI
2003 Aprilia RST 1000
1999 Victory V92C
Proudly serving the citizens of the United States in the United States Coast Guard, 1988-Present.
09-14-2009, 09:20 PM
2 reasons , they look cooler and because i want too
09-14-2009, 10:15 PM
fair enough.
2006 FLHTPI
1999 Victory V92C
09-14-2009, 10:31 PM
Premium octane member
Love my chain. not a pain at all. Been running it all season with no problems. Talk to Andy at 3 guys, he will set you up nicely. Zippers also has a kit that might be a touch cheaper also.
Here is the chain "needs" kit i got from Andy!
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
09-14-2009, 11:00 PM
friggin sweet, can you tell me what teeth you are running, front and back, and do you remember what the front sprocket offset is?
.500 sound right? ok let me rephrase this i can count the teeth in the pics, but how do you like the rpm on the highway, is your bike a 5spd or 6 and maybe the front sprocket is a .900 offset
09-15-2009, 09:36 AM
chains arent a hassel at all, since the early 90's all ya do is the adjustment for initial stretch, and clean when dirty. no oil sling, no stretch, just go ride!
BTW, i always favored tsubaki.
09-15-2009, 07:52 PM
does anyone know what off set you need on the tranny sprocket for a stock 03 road king
09-15-2009, 11:04 PM
call 3 guyz talk to randy man... he will tell you what you need.
 08 crossbones
hillside 107
woods tw8 cams
hillside stage 3 heads
s&s roller rockers
s&s adj pushrods
55 hpi throttle body
larger injectors
D&D fatcat-perf baffle
vp92t
hillside air filter
230 ccp
not one ounce of pinging
hillside cycle...
09-15-2009, 11:13 PM
cant wait to convert my to chain this winter... gunna have to husle andy for a 630 setup for a 200 rear tire crossbones..
 08 crossbones
hillside 107
woods tw8 cams
s&s roller rockers
s&s adj pushrods
larger injectors
vp92t
hillside air filter
230 ccp
hillside cycle...
09-23-2009, 09:21 PM
so i emailed those guys like over a week ago and still no response, 3 guys garage
09-23-2009, 09:36 PM
I have been thinking of chain drive too, but my biggest concern is having to pull the inner primary to change the front sprocket. I can not imagine the front sprockets can last over 15-20,000 miles before needing replaced. That is about a year for me. Stock pulley still looks good at 74,000. My biggest reason for changing is it would be easier to repair a broken chain on the road vs a belt. WOuld not have to pull the primary or swing arm to replace the chain and pretty easy to carry a spare chain with you.
09-23-2009, 09:49 PM
Give them a call if you can. I tried email first and it took a little while to get back to me. Every time i called though, Andy picked right up.
That is a very valid concern. I dont see a sprocket lasting that many miles either. My guess, front 50k, rear, 20-30k. I only have about 5k on mine and shows no wear yet. I am pulling my tranny this winter, so i will inspect the front pulley. I suspect it wont show any wear yet though. If you ride that much its probably a ton cheaper and easier to keep the belt.
Mikuni HSR48
Black Boarzilla
