Motorcycle.com Classifieds!CycleGear.comSportbikeTrackGearMotorcycle.comRRcycles.com
Dan Vance RacingJardineProducts.comAmerican Side Road Cycle
Dan Vance Racing
Old 09-13-2009, 02:09 PM   #1 (permalink)
mgxlch is on a distinguished road
Sticking Clutch
Hi Guys,
Just replaced the oil seal on the gearbox and on re-assembling the primary side am having problems with the clutch, it's a five stud basket and springs instead of the three and the hassel I am having is clutch drag. With the bike running put her in gear and she wants to move forward, rev the bike up and the clutch feels disengaged, no drag, and then gradually the drag re-appears after a couple of seconds with the clutch lever pulled, I have adjusted the plate as the book says but this is with the three spring clutch, is the five spring different or I have just got dirty plates?
Forgot to say the bike is a 1982 FXRS
Brian
mgxlch is offline   Reply With Quote
Old 09-13-2009, 02:19 PM   #2 (permalink)
DILLIGAF
berserker's Avatar
Clutch are just weird. I have tried tapping the shaft on primary side with rubber mallet. My problem typically has been to hard to pull. Where I end up taking the balls apart and redoing them. Cover them in grease to hold them in place.
If you touched the lever with the clutch off, your balls are out of whack. But that usually shows up as hard or won't pull.
Old 09-13-2009, 03:56 PM   #3 (permalink)
loosen everything , on your basket tighten your adjuster screw till you feel tention then loosen it 1/2 turn - put a nickel between your clutch lever and tighten your clutch adjustment on the line then try taking it for a ride.
Old 09-13-2009, 05:56 PM   #4 (permalink)
I think you are going to have to get a service manual that covers your clutch, many guys here think that all clutches are like the ones in their (late model) bikes...The five stud clutch was used until around mid year `84 I think.
Dan89FLSTC is online now   Reply With Quote
