09-06-2009, 12:39 AM
Help? Paper towel in transmission...
My neighbor dropped a small dime sized piece of paper towel into his transmission after checking the oil. It was a small tear off that was loose and just happened to fall in. I offered to help and tried to grab it with a pair of Hemo's and it fell in further. I tried to fish it out with a wire, but nothing came up. I figured it would get shredded up through the pump, but fear it might now. Any advice? Appreciate anything you can offer up....
09-06-2009, 12:55 AM
Old married guy
I don't think the transmission has a pump it splashes. The tiny piece of paper will be gone in seconds.
09-06-2009, 01:19 AM
Formerly 04GLIDE
Ride a few hundred and change the oil. Done
09-06-2009, 02:09 AM
Thanks guys, I should have mentioned it was a road king twin cam, not sure what year but post 2000 for sure. I feel somewhat responsible because I thought I could get it so I offered it and I knocked it in further. Anyone else want to offer their two cents it is certainly welcome.
09-06-2009, 02:16 AM
FOG
There's no transmission pump. I agree with 03Glide.....ride it and change it. I'm not sure changing it is needed, but I would.
trooper113
NRA Endowment Member
AMA Member
09-06-2009, 06:33 AM
The trans will grind up that paper no problem, even a bottle cap with no damage.
09-06-2009, 10:20 AM
I'm Your Huckleberry
Originally Posted by kemo
........ even a bottle cap with no damage.
There's a back story here... I can feel it.
The Fair Tax- (go ahead, click it.)--
'07 Ultra -> Covington, Ga.
09-06-2009, 11:21 AM
No story Cujo just figure that there are no lube circuits or pumps to plug, just oil being splashed around. I did drop a speedo gear in a manual car trans once and the service department told me then not to worry about it. Never did no harm, I guess you are right though there is a back story.
09-06-2009, 12:55 PM
Way back in the day I dropped an allen wrench in an old Ford tranny.. I'm guilty too.
09-06-2009, 10:53 PM
mooooving out!
Con men used to put wood shavings and banana peals in transmissions and rear ends - it would quiet them up and did not seem to do extra damage.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
09-06-2009, 11:41 PM
Hemo's huh? Hmmm.... why do you have those? No problem set and forget it. You may have stumbled on the cure of the 3rd gear whine. BTW what whines more the owner or the 3rd gear?
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
09-07-2009, 01:57 AM
Old married guy
Maybe that's why things are falling here they shouldn't......
09-07-2009, 03:14 PM
Formerly 04GLIDE
Was this paper towel or rolling paper?
09-07-2009, 03:22 PM
DILLIGAF
Agree, on a big twin, probably not a big deal. The stock dipstick flakes more cheap as chrome then that, and so far so good.
09-11-2009, 02:43 PM
LMAO!
J♦B
