Chroming/Replacing trans side cover (trans door, trap door, bearing housing)
On my 93 Wide Glide I was able to use JIMS Transmission 5-Speed Bearing Housing Remover and Installer to remove my old trap door and replace it with a chrome billet part. The exahust mount hole on the trap door was stripped out (not all models use this ear/hole). To use this tool you have to remove the exhaust, trans side cover,the trans top cover and then the trap door mounting bolts. You then put the trans in two gears at once (through the top cover). Remove the bearing main and counter shaft retainers and lock nuts. Use the tool to pull off the old trap door. Put the new/chromed trap door on using the tool. And, button it up.
I realize that this was an old post. But, I have just run into this problem and thought I would share my solution. Price.....
Reason: Misspelled word
