Used to use a Magura setup on a racing ATV. Never had an issue with heat, except when the plastic line was melted on a pipe, the stainless replacement lines are much better.
Mineral oil, or Magura oil are the ones to use.
Bleeding the setup is pretty difficult, you might bleed it again just to make sure there isn't any air in the line.
